Just one more question before I buy
Old Feb 11, 2009 | 08:53 AM
nikki&petey's Avatar
Default Just one more question before I buy
So I know I want either an 07 or 08. But do I want a Touring model or not? I am unclear on the difference between the two. I would hate to not get the Touring model and find out later I should have gotten it, or vice versa.
Opinions?
Old Feb 11, 2009 | 03:16 PM
bwilson4web's Avatar
Engineering first
Default Re: Just one more question before I buy
Hi,
Some folks have reported that the Touring model has a little stiffer body that improves handling. In fact there is a 'stiffening plate', an after-market part, that folks have added to their Prius to make the body and handling more sporty. But I have no direct experience with either NHW20.
Personally, I would go with:
  • price range - figure out how much can afford to buy and that is your budget
  • cooler climate over hot - Prius from cooler climates will have had a nicer life than those from the hottest places that can heat stress them
  • accessories - stuff is nice
I would also budget "new tires" in the first year. Unless you are very, very, very lucky, I always expect used car tires to not last much more than a year. I can not explain why but that has been my experience. The tread just seems to 'melt away.'
Bob Wilson
Old Feb 12, 2009 | 01:26 PM
David Beale's Avatar
Touring model has:
1. Larger rear spoiler.
2. Slightly stiffer shocks, same springs.
3. 16" wheels instead of 15". Both are aluminum wheels. The tires are also -slightly- better quality. Both sizes have the same overall diameter and are interchangable, though you shouldn't mix them.
4. Slightly poorer mileage, perhaps 5-10%, due to more traction on the road, mostly.
5. Different option packages.
The body is identical.
I have the non-touring. I put Nokian WR tires on it pretty much when it was new, so I suspect my traction is at least as good as the touring. These tires made the proverbial "night and day" difference. They are true snow/ice tires, but don't wear unusually rapidly in summer, so are real all season tires. They -did not- drop the mileage. The mileage may actually be slightly better than the 15" non-touring stock tires. Perhaps 2-4% better. This small a change is hard to attribute to any specific factor.
travelover
Jul 21, 2012 11:27 AM
pawel
General EV Discussion
Oct 27, 2011 07:40 PM
torque63
Off Topic
Mar 19, 2009 05:32 PM
belbe
Jul 4, 2007 12:33 PM
