Fuel Tank Capacity
Old Apr 22, 2007 | 10:05 AM
charlie00's Avatar
Default Fuel Tank Capacity
The fuel tank specification is 11.9 gallons - yet the most I can ever add is about 9.8 gallons. At that level I received an engine trouble light and the gas engine turned off. Is this a sensor or computer issue? Anyone experience the same thing? I will call the dealer tomorrow. Thanks.
Old Apr 22, 2007 | 11:04 AM
bwilson4web's Avatar
Engineering first
Default Re: Fuel Tank Capacity
Hi,
New car?
You might check the Prius forum and read the FAQ. The only real problem known is if you overfill the tank, try to put in more than the pump 'cut-off', you can leak gas into the vapor recovery system. That can be a very expensive problem.
http://priuschat.com/the-gas-bladder...ed-t31545.html
So do you run the tank dry and then only get 9.8 gallons in the car?
Bob Wilson
Old Apr 22, 2007 | 01:15 PM
singingtiger's Avatar
Charlie00
Let us know what the dealer found out.
The only "normal" situation for the tank to hold just 9.8 gallons would be for those of us who live in a cold winter environment when the flexible tank size decreases.
Old Apr 22, 2007 | 09:35 PM
Pravus Prime's Avatar
Prof. of Hybridology
Off to the Prius forum with you!
Old Apr 22, 2007 | 10:37 PM
Resist's Avatar
My understanding is the bladder in the U.S. version is the cause.
PeterMax
Jul 17, 2008 07:34 AM
masterboy27
Feb 13, 2008 05:20 AM
ahadave
May 26, 2007 02:28 PM
bar10dah
Aug 15, 2006 11:16 PM
jbtaco2002
Sep 22, 2005 06:54 PM
