Crazy Gas Mileage
Old Oct 19, 2005 | 12:40 AM
Chris Franks's Avatar
Default Crazy Gas Mileage
I have been getting exactly 45 mpg from my 2004 Prius every 10K miles for the past 35K miles, summer and winter. On my birthday, Sept 29th, my stepson gave me an electronic tire pressure gauge. I checked all my tires, and they were all around 30 psi, so I increased them all to 36 psi. Now, for the last 4 tanks, I am getting 57 mpg!!! Same roads, but A/C off and windows open.
I suspect that the gauge reads low, but the ride is still very comfy and grippy, so I plan to leave it at 36 on that gauge.
Old Oct 19, 2005 | 03:40 AM
LarsBoelen's Avatar
Default Re: Crazy Gas Mileage
FE Tip 1 : Don't speed
FE Tip 2 : check tire pressure, keep it high
I bet that gift turns out to be lot bigger than you thought it was when you got it!
Old Oct 19, 2005 | 05:47 AM
jdenenberg's Avatar
Engineering Professor
I had a similar experience int the last month, but not quite as dramatic (46 -> 51 by going from 36/34 psi to 42/40 psi, but I'll wait for more data to see how it averages out). The beauty of this is that it improves MPG at all speeds.
Old Oct 19, 2005 | 06:58 AM
Clubford00's Avatar
Ive gone as high as 44 psi (max psi as written on the tire) i was wondering how high has anyone gone as far as psi ??
Old Oct 19, 2005 | 04:09 PM
xcel's Avatar
Hi Clubford00:
___I have used 60 - 62 in an Insight and I have seen 62 in a Prius II. Both with absolutely no problems … Except the mileage increase
___Good Luck
___Wayne R. Gerdes
___Waynegerdes@earthlink.net
ModelinaHybrid
Oct 30, 2007 12:59 PM
benb
Jun 16, 2006 10:11 AM
MGBGT
Jul 1, 2005 11:53 AM
Schwa
Jun 29, 2005 04:48 PM
