Coastal E Tech mod - successful installation, tips
Old Mar 12, 2007 | 12:59 PM
kamsmart's Avatar
Default Re: Coastal E Tech mod - successful installation, tips
Wow .. cool, soopahman!
Old Apr 5, 2007 | 04:06 PM
SoopahMan's Avatar
I've had a lot of visitors this past month who consistently wanted to visit San Diego and Mexico, which has put me on the highway a lot and prevented both the Mod and the acceleration technique from having much relevance. However there was just one tank where I was able to stay off the highway and get:
61.5mpg
For the entire tank - that's not MFD that's the real miles/gallons ratio. That's using the EV mod gas engine shut off for the first 5 minutes, and accelerating just hard enough to not use the battery.
https://www.greenhybrid.com/compare/...r.php?cid=3783
The vacations are all over with (no more visitors for a few months) so I should be back to local driving for the next couple of tanks, we'll see what I end up with.
Old Apr 15, 2007 | 09:23 AM
David Beale's Avatar
So nobody is worried that Toyota has stated installation of this mod will void their battery warranty?
Just wondering what the thinking is on this.
Old Apr 15, 2007 | 02:44 PM
SoopahMan's Avatar
David, have a search through this forum and on PriusChat.com, warranty worries are covered there. As a summary, there are some concerns but the majority opinion appears to be it's a non-issue, with one person pointing out that a Toyota mechanic actually noticed the mod and complimented the owner on it - no voided warranty.
Old Nov 6, 2013 | 09:01 AM
Enginerd's Avatar
Picking this thread up, I recently purchased a 2010 Hybrid Highlander and am curious if the CoastalTech EV mode modification would work in the same way as on Prius, i.e. grounding pin 27 on the H17 connector (even if the connector is called B1 or B2 or B3 and not H17). The cancel on the cruise control is OK but I think I would prefer to just put a different switch in somewhere. Sounds like it is true EV mode and not like the EV mode switch that only works when the engine is warm, is that right? Hoping to do my own plug-in conversion sometime and this is step 1. Any comments or hints would be appreciated, thanks!
gpsman1
Sep 16, 2019 05:08 AM
Enginerd
Toyota Highlander Hybrid
Nov 26, 2013 05:31 AM
Joe.B
Aug 4, 2009 12:24 AM
caholla
Mar 23, 2008 08:55 AM
GunnyE7T
Apr 17, 2007 05:45 PM
