Best replacement tires for prius 100K jeff
I have tried to original Integrity and Michelin Hydro-edge... and both were just OK now I need new ones any good suggestions and where to purchase? thanks Jeff from va.
You need to be more specific in your requirements:
1) maximum handling
2) maximum efficiency
Don't say "both" because that lets those who make a recommendation decide on your requirements ... you might as well talk to a tire salesman.
GOOD LUCK!
Bob Wilson
1) maximum handling
GOOD LUCK!
Bob Wilson
MOre specific the Hydroedge ended up with terrible cupping and I need to return to the orginal tires (Integrity) or with something else... Mileage was about the same for (both GY and Michelin) 52 mpg!
I just need some advice for the Next set... for my 05 Pruis (110 K)
Do you have the numbers from a recent alignment report? We need both front and rear, toe and camber.
Abnormal wear is an alignment problem and needs to be fix BEFORE the next set of tires. New tires on bad alignment ensures they will wear out too soon.
Bob Wilson
Jason
Hybrid & Related News
Sep 30, 2004 02:42 PM
