600 mile tank -- Prius Classic
Old Aug 22, 2007 | 03:07 PM
bwilson4web's Avatar
Engineering first
Wink Re: 600 mile tank -- Prius Classic
Originally Posted by mikel
Almost! 583.5, and all I could squeeze in to the tank was 10.4 gallons. I guess I could have gone a little further, but I was already getting nervous with the last pip blinking most of the day and knowing the next gas station was around 20 miles away.
When you get down to the last quarter tank, carry a 1 gallon, spare can in the trunk. Just make sure it is secured so it can't slide around or tip over. Then drive until the ICE stops and all the lights come up. Slow down and EV to a safe area to pour in the spare gas and you'll be set. Piece of cake!
Bob Wilson
Old Aug 23, 2007 | 06:48 AM
tekn0wledg's Avatar
Default Re: 600 mile tank -- Prius Classic
Is there any damage to the vehicle in doing that Bob?
Old Aug 23, 2007 | 07:23 AM
Engineering first
Hi,
Not that I can identify. If it causes a problem my roughly 10 times running out have not revealed a systemic problem. I'm testing with my 03 Prius, NHW11 model. Once my gasoline studies are complete, there won't be a need to do it any more. The winter-fall gasoline studies will complete this effort.
Toyota recommends against running out of gas. There have been speculations about fuel pump heating and injector wear from running dry but so far, no empirical data about a problem. It also puts a significant load on the battery when you flip into EV mode but no worse than maximum acceleration testing.
I do not recommend it as a standard practice. The last time I ran out of gas was unexpected on a limited access highway approaching an interchange. Now I'm used to it, I handled it without a problem. However, the surprise of it might cause folks to not pay attention to the current traffic situation.
My personal thinking is running out of a gas once with a spare can is useful for 'the experience.' It means should you have it happen by accident, you'll not be going through it for the first time. But each driver must look at their own skills and comfort level to determine if this has merit.
Bob Wilson
Old Aug 23, 2007 | 02:57 PM
tekn0wledg's Avatar
Right. Thanks Bob.
I am thinking about testing it so I understand the flashing PIP better. I will probably let it run down on my next tank with a spare in the car after I get down to the last PIP.
Old Aug 23, 2007 | 06:57 PM
Tochatihu's Avatar
I suppose that both overfilling and 'running dry' have the potential to damage Prius. So far, only overfillings have been demonstrated to do harm (and that but rarely). In fact I know of a new-model Prius driver in Orlando who seems to spend most of his time driving on blinking E, with no problems at 73k odometer.
The problem here is that the fuel tank assembly must be replaced entire, and at considerable expense. That was generally enough to keep me away from both extremes. I take different risks, and we all ought to chose our own.
DAS
Old Sep 11, 2007 | 07:28 AM
mikel's Avatar
I did it! 603.3
Mike
Old Sep 11, 2007 | 10:13 AM
Engineering first
Talking Re: 600 mile tank -- Prius Classic
I did it! 603.3
Excellent!
Bob Wilson
Old Sep 24, 2009 | 07:36 AM
mikel's Avatar
Did it again this week. 605.9 on 11.74 gallons. I wasn't trying to hit 600 until I saw I was at 530 yesterday and the last pip wasn't blinking yet.
Mike
toast64
Off Topic
May 6, 2008 11:03 PM
gonavy
15
Jun 23, 2006 05:45 PM
clayk
Oct 28, 2005 06:59 PM
JeremyG
Oct 13, 2005 01:37 PM
KLCarch
Jun 9, 2005 12:02 PM
