2005/2006 Prius questions
Old Apr 12, 2006 | 08:19 PM
himster's Avatar
Question 2005/2006 Prius questions
Hi, I purchased a Prius 2005 over a month ago and I have a few questions about it. Thanks in advanced.
1- How bright are the headlights supposed to be?
When I drive my Prius during the night a lot of cars flash me their lights telling me I'm driving with high beams but I'm NOT!!! So I took the car to the dealer and they told me the lights were at the right level.
2- Do you have a glare from the green control panel that reflect with the windshield while driving at night?
First time I drove at night with my Prius I noticed this glare but it doesn't really bother me anymore. I just wanted to know if they fixed that problem in the '06 Prius.
That's all the questions for now. Other than that I love my Prius, if I have more questions I'll post them later. Thanks!!!
Old Apr 13, 2006 | 08:39 AM
ralph_dog's Avatar
World's First Hybrid
Default Re: 2005/2006 Prius questions
For question 1: If you purchased the vehicle used, the previous owner may have swapped out the halogen headlight bulbs and installed HID headlights (which are 3x brighter) and high voltage ballast without changing the entire reflector assembly. ??? Check to see if they are indeed HID bulbs (look for a ballast module somewhere under the hood) and then look on the outside front of the plastic headlight assembly to see if there is an "HID" imprint or "HB2" or "HB3" imprint. If the bulbs are HID (high intensity discharge) and you have "HB2 or HB3" imprint (for halogen only), then you will need to remove the bulbs and high voltage ballast system and replace the bulbs with std halogen lights.
Or maybe the previous owner replaced the low beam halogens with the wrong part (high beam halogen).
If you like HID lighting, then you will need to replace the whole reflector assemblies with OEM parts. Will cost you plenty of cash, maybe 400-800??? depending on where you get the parts and if they are available for your model Prius.
Can't answer question 2.
Old Apr 13, 2006 | 09:52 AM
sweetbeet's Avatar
Happy Hybrid Owner
I just got an '06 Prius in January, without the HID headlights, and I too get "blinked" a lot. I assume the lights are adjusted properly since I just bought the car new. I think it must just be something about the configuration that seems "high" to some people. We had the same problem with our Ford Escapes, I assumed it was because it was a bit higher off the ground than most cars, but that's certainly not true of the Prius.
Didn't notice any particular glare on the windshield, but I'll check again tonight.
Old Apr 13, 2006 | 10:01 AM
Phebos's Avatar
I have both problems aswell. The other drivers think that I am on high beams too. I just turned the high ones on a couple of times and no one flashes me anymore.
As for the glare on the windshild, if you lower the brightness of the HUD it goes down.
Old Apr 13, 2006 | 11:09 AM
kdhspyder's Avatar
From: Two miles N of the technology 'center-of-the-world' in 1903, on the Outer Banks of NC
You weren't given the 90 min delivery when you picked it up were you?
Actually tonight when you drive use the 'roller dial' for the dash illumination. If it's set on normal daylight setting; i.e. 'full glare' , turn it down slightly toward the floor. You will feel a 'ridge' immediately and once over the ridge your screen and HU display will go to a darker background and the glare on the windshield will go away.
Did you get the one week, two week, 4 week SKS disabling tour?
Old Apr 13, 2006 | 12:53 PM
sweetbeet's Avatar
Happy Hybrid Owner
Wha? "1 week, 2 week, 4 week SKS disabling tour"??? Please explain!
Old Apr 13, 2006 | 07:23 PM
himster's Avatar
I'm sorry....I also did not understood about the tour.
Ralph_dog I purchased my car brand new, so I'm sure it doesn't have those annoying blue halogen lights...my car came straight from the dealer...well it actually had 700 miles on it but it was the test drive one from the dealer. I got a nice deal that's why I got the 2005. The only thing I regret about it is not getting the 2006 which comes with mp3 player.
Old Apr 15, 2006 | 06:59 PM
PriusGuy04's Avatar
I had this probelm on my 04 the floating head light reflector had to be ajusted down like a 1/2 inch at the dealer no more flashers the illumination was still the same you just arent squirrel hunting...
P.S. I went to the dealer and they told me the lights were properly ajusted.. I told them to reajust them down a little.. they did and no one flashes me any more these where the Halogen stock head lights.. Theres nothing wrong with your car just ajust the head light reflectors down a little....
Old Apr 15, 2006 | 08:09 PM
himster's Avatar
Thanks PriusGuy04, I think that's the problem and I guess I have to give a visit to the dealer.
Old Apr 16, 2006 | 06:38 AM
sweetbeet's Avatar
Happy Hybrid Owner
Yeah, thanks, I'll mention it too when I take mine in for the first (5K) service in a month or so.
