1997 - 2006 Prius
Old Feb 25, 2006 | 02:22 PM
JeromeP's Avatar
Default Re: 1997 - 2006 Prius
Originally Posted by ken1784
http://en.wikipedia.org/wiki/Toyota_Prius
The body styles are same, but 1997 Prius has black rubber on bumpers.
Ken@Japan
Yep, that is definitely the 1997 Prius. Not a show car. The wheels are also correct for the Japanese version.
Old Feb 25, 2006 | 08:08 PM
ken1784's Avatar
Originally Posted by plusaf
why capacitors? they don't store nearly as much energy as batteries....
The super capacitor hybrid truck was sold in Japan by Nissan Diesel since 2002.
http://www.nissandiesel.co.jp/low-env/s-capacitor.htm
http://www.nissandiesel.co.jp/low-env/system.htm
Ken@Japan
Old Feb 25, 2006 | 08:43 PM
plusaf's Avatar
Ken@Japan
thank you, Ken...
well, that sure clears that up!
i'm sorry, but i only know a very few words of spoken Japanese, and can't read 'em at all. the online translation didn't add a lot of info, though...
how big are the supercapacitors that were used in that truck?
aha... read both translations.. 1,500 Farads. 583 watt-hours.....
so my Camry's 70-Amp-Hour battery, at maybe an average of ten volts, stores about 700 watt-hours? one car battery = 1.2 x 128 cells of a 1,500 Farad supercapacitor.
hmmmm.... i'm not sold yet...
please explain what i'm missing, here? a few decimal points?
i think, from my EE estimation, that the supercapacitor is a very nice way to supply super-high peak currents for a short time for the traction motors, alleviating some hign-current charge and discharge stresses for the batteries.
but there just ain't enough energy in there to move the car more than, well, feet, or dozens of feet, but no way: miles.
any math majors or physics majors out there who can help?
Last edited by plusaf; Feb 25, 2006 at 08:53 PM. Reason: i read the translated page
Old Feb 26, 2006 | 01:28 AM
ken1784's Avatar
Let's face the 583 Wh spec.
Why do you compare it to your Camry 12V battery?
Let's compare it to hybrid battries.
(Please note that we use about 20% of the whole capacity.)
Prius: 202V X 6.5Ah X 20% = 260 Wh
HCH: 158V X 5.5Ah X 20% = 174 Wh
The good thing about the supercapacitor is low internal resistance and very long cycle life.
Ken@Japan
Old Feb 26, 2006 | 09:47 PM
plusaf's Avatar
Ken@Japan
exactly right, ken... the point i was trying to make was that, it keeps sounding to me like people are expecting supercapacitors to replace batteries in electrics or hybrids soon, and i'm very doubtful of that until they're at least about one order of magnitude better in energy density or capacity.
the drive battery is only used for 20% of its capacity because deep-discharge is definitely not one of its strengths. the supercapacitor, i'm guessing, doesn't care about deep discharge, but that also means the assumption of going from fully-charged to fully-discharged, and believe me, i wouldn't envy the engineers who'd be tasked with converting anywhere from zero to several hundred volts into something to send to a drive motor.... that kind of range would pose some challenges that would either send them off a tall cliff or have them end up with a design range of using just the top 20% of the supercap's juice, just like the NiMH cells of today!
i do think that supercaps will shine in hybrids as short-term energy sources,maybe for better off-the-line acceleration or to offload the drive battery up to maybe 30 mph instead of 10-20.
imnsho...
Old Feb 27, 2006 | 03:04 AM
Schwa's Avatar
The combination of super caps and battery for long-term energy storage would be the best solution. The problem with the battery in the Prius is that it can only deliver around 20kW, yet the main traction motor can use 50kW, so the difference has to come from the ICE generating through the smaller motor. I have a feeling that new capacitor technology as well as battery technology will eventually kind of merge in the sense that both will be in use, and they will share some common chemistry.
Lithium Ion Capacitor anyone?
http://www.greencarcongress.com/2006...eavy_lice.html
Old Feb 27, 2006 | 01:58 PM
plusaf's Avatar
yes, that sounds teriffic! and we can only imagine what at GenIII or GenIV Prius would do with double- or quad-power-density batteries, plus supercaps!
wow!
but keep in mind: batteries store energy by chemical reactions, in a simple sense; capacitors do not. their energy storage is in stretching or distorting the molecules or atoms, while piling up electrons on one terminal and depleting them from the other, in the insulating, or dielectric material, not by chemically changing them.
yoondds
EV Customization
Jan 13, 2010 06:07 PM
PriusGuy04
Feb 20, 2006 06:23 PM
ericbecky
Events & Gatherings
Jan 28, 2006 03:25 PM
