water pump and timing belt
Old May 30, 2014 | 07:07 AM
bandit88's Avatar
Default Re: water pump and timing belt
Originally Posted by MTL_HiHy
GM isn't all bad, but I agree they need quite a bit of help to compete with other auto makers nowadays. I've got a Duramax which I love (blows the doors off a Tundra for pulling and the transmission is a tank), but ironically the engine is designed by Isuzu (which is Japanese) and a fuel system by Bosch (German). GM's attempt at hybrids has been very lack luster, but Toyota has been a leader in that area IMHO so it's like comparing apples and oranges really. The Highlander Hybrid is a heck of a vehicle (7 person seating and amazing fuel economy) so I totally know what you mean.
No worries on the accessory belt, better to have the right info out there so no one gets confused later.
the duramax paired with the allison transmission is no joke. I do agree that many of GM hybrids were unnecessary to produce;however, The Volt truly is my opinion an amazing car. I have seen them come in with 5-25k miles on them and averaging 150mpg.
I do agree the highlander is a great vehicle. I hope one day they will produce a plug-in version that can go 20-25 miles on a charge before needing to use the ICE.
Old Jun 11, 2015 | 08:42 AM
estcstm3's Avatar
I guess it's a bit different up this way, garages are a bit more accommodating since they are small communities and screwing people doesn't win over customers long-term. That being said if you have a decent independent garage willing to order parts from Toyota (even at list price) and install/warranty them for you, then I'd certainly feel comfortable going that route. As a former professional mechanic myself I've seen some pretty bad aftermarket stuff so I definitely prefer paying a bit more for the OEM parts because at least you know it will perform similar to what it came with originally (I'm especially referring to the water pump in this case, belts aren't that big of a deal either way.......bad accessory belt won't kill the motor but a bad water pump sure can).
You and Bandit88 seem to know your stuff.
i have a 2007 highlander hybrid that with 140k that I just got from an inlaw. I will be replacing the timing belt. I was going to do it all, belt, tensioiner, bearing, waterpump (this kit as they are all guinue parts). I then read that our cars do not have a belt for the water pump so is it really neccesary to change?
http://www.ebay.com/itm/AISIN-Water-Pump-Timing-Belt-Overhaul-Kit-981-84006-Toyota-Highlander-V6-04-09-/361252580641?fits=Model%3AHighlander&hash=item541c54ed21&vxp=mtr
WATER PUMP with GASKET
TIMING BELT
IDLER BEARING
TENSIONER BEARING
HYDRAULIC TENSIONER
CRANK SEAL
CAM SEAL
A/C AIR CONDITIONING BELT
ACCESSORY BELT
THERMOSTAT with SEAL
Old Jun 11, 2015 | 08:49 AM
bandit88's Avatar
Your engine waterpump is driven by your timing belt. You should replace the water pump, tensioner, and idler when changing the timing belt. It's only good practice to do so. That way you have good faith in the parts.
Old Jun 11, 2015 | 11:15 AM
estcstm3's Avatar
Do you think the kit i linked to from Ebay should do the trick?
Old Jun 11, 2015 | 06:22 PM
MTL_HiHy's Avatar
Yes, the kit you linked to is a good one (ie all OEM parts) and I definitely suggest replacing all the parts in the kit when you do your timing belt. It takes a bit more time but saves you alot of headaches in the end.
Old Jun 11, 2015 | 07:03 PM
estcstm3's Avatar
Any chance you all did it yourselves? If so did you use a service manual?
Old Jun 11, 2015 | 07:23 PM
MTL_HiHy's Avatar
Just use Alldata DIY if you need access to service manuals for your vehicle.
https://www.alldatadiy.com/
cbxtc6
Sep 15, 2014 12:54 PM
tedson99
Jan 5, 2013 11:00 PM
renod
May 6, 2011 01:33 PM
UWAdventurer
Jun 24, 2010 07:48 AM
spent2much
Feb 19, 2010 06:42 PM
