New Highlander Hybrid arrived!
Old Nov 9, 2008 | 07:54 AM
  #31
rdalemercer's Avatar
Default Re: New Highlander Hybrid arrived!
Help?
Originally Posted by philmcneal
When you add or remove air in the tires, you have to recalibrate your tire pressures! Check your owners manual for more information, unless you want to ignore the tire pressure light system.
I've checked tha manual but didn't find where I can recalibrate the TPMS? I'd like to try running at 35 PSI, but I won't do it if that causes the idiot light to stay on all of the time.
Do you know of a method to recalibrate the TPMS?
Old Nov 14, 2008 | 10:42 PM
  #32
philmcneal's Avatar
04 prius 350,000km
if there is no button below under the steering column, then you have to use the techstream tool scanner :S
i need more information will post when find
JSuppi
Toyota Highlander Hybrid
Nov 8, 2020 12:51 PM
just522
May 22, 2008 05:00 PM
spacebug
Honda Insight
Sep 6, 2006 05:10 PM
traceypowers
Honda Insight
10
Aug 15, 2006 07:54 AM
lakedude
Aug 15, 2005 09:52 PM
