Maintain 40 mph
Maintain 40 mph
I bought my highlander about two months ago. I was disapointed with the MPG as well. Now I am a little bit happier now since the MPG is improving. The key is to maintain 40 mph using battery only. I found out that the best way to improve mpg is maintaining speed using battery only. 40 mph is the best speed to do so on a relatively flat or small uphill. I have short drive to/from work (7 miles). I am happy getting 28 mpg.
Re: Maintain 40 mph
peter
congrats on your highlander. We too were getting 22mpg until i realized driving with the ICE and EV working in tandam gives the best mileage. The thing with driving in EV is that it depletes the batteries very quickly, thus the ICE has to come on to recharge it, instantly draining your mpg. So, having the battery constantly charged at around 40-45 mph has given us consistent readings of over 30mpg -with the ICE on.
The idea of driving in EV though , is the main reason i am chaffing at the bit for plug in hybrid options to make their way onto the scene.
Re: Maintain 40 mph
Originally Posted by tomdavie
foo
what is this 'pulse and glide' , maybe i will give it a try.......
Obviously, you can only P&G where traffic conditions allow it. You don't need to do both, either. Once you get the hang of gliding, you'll find lots of places to use it. From your first post, it sounds like you're using the electric motor at times where you could glide.
I've never driven a HH, but I've heard the glidingg technique is not as easy to do, as in a Prius. You also won't glide as well, but it's worth a try.
Re: Maintain 40 mph
I bought a SUV. I really don't want to drive 30 mph or 35 for that matter. 40 mph is a right speed if you don't want to drive aggressively. In my oppinion, the key to drive hybrid is to use the battery efficiently. Toyota should have done a better job allowing you to do so. In my experience, the most efficient way to use the battery is to maintain speed at 40 mph using battery only. It is very sensitive. If you press the pedal a little bit harder, engine will kick in. If you press the pedal a lit bit softer, the car will slow down. Toyota should have designed better. While driving in the city you have enough opportunities to recharge your battery (stops).
Short trips kill mpg. I was doing 1.5 mile trip daily to YMCA and 7 miles trip to my work daily. The mpg (manually calc) was about 26. I started using my wife's car for the YMCA trip (experiment for one tank. I am not crazy enough to switch cars to gain mpg). I am getting 29 mpg this tank. It is not 33 mpg but makes feel somehow better about my purchase
Nagorak
16
08-15-2006 08:33 AM
