Highlander Hybrid Hacks and Easter eggs?
Old Mar 6, 2007 | 02:17 PM
highlanderhybrid's Avatar
Default Highlander Hybrid Hacks and Easter eggs?
Are there any easy Highlander Hacks or hidden easter eggs for the base model Hybrid Highlander like there are the Prius. Is there a way to mod an 06" Highlander Hybrid for an EV button?
Old Mar 6, 2007 | 02:30 PM
w@ntonsoup's Avatar
Default Re: Highlander Hybrid Hacks and Easter eggs?
The only hidden feature I know is that you can turn on the nav override so you can program it while moving. That works in the '06 models only I think.
There is no EV mode.
Old Mar 6, 2007 | 05:24 PM
ilene's Avatar
Can you please reveal how to do the override?
Old Mar 7, 2007 | 04:55 AM
WebG's Avatar
similarly, has...
anyone installed an EV-only button in an '07 Highlander?
figured out the '07 nav bypass code? (and for that matter, the bypass code for an '02 Lexus ES 300, if you allow me a slight digression)
Old Mar 21, 2007 | 11:28 PM
DesertHH's Avatar
see http://hybridcars.about.com/od/owner...vigation_8.htm for nav override
Old Mar 22, 2007 | 10:37 PM
ken1784's Avatar
The Hybrid ECU on Prius has the EV-switch function, and the EV-switch is factory installed for Japan, EU and AU market. No switch is installed for NA market.
The Hybrid ECU on '07 Highlander Hybrid does not have such function even for Japanese market, so EV-switch for '07 Highlander Hybrid is impossible.
However, it looks the EV-switch will come as default on '08 Highlander Hybrid.
http://pressroom.toyota.com/Releases...T2007020756841
"Highlander's advanced Hybrid Synergy Drive system has been extensively upgraded and refined for 2008 for both power and economy, including a first-ever full EV mode."
Ken@Japan
Old Mar 23, 2007 | 05:22 AM
WebG's Avatar
Originally Posted by DesertHH
tried that and looked all over online -- it looks like that code sequence was disabled for the '07.models.
Old Mar 23, 2007 | 08:57 AM
w@ntonsoup's Avatar
Yep, that's been widely reported. The new '07 nav system doesn't use the same (if any) override sequence.
nsxman2001
Oct 19, 2014 06:26 AM
kskruser
Mar 6, 2012 10:11 AM
KarlWireless
Toyota Highlander Hybrid
15
Oct 23, 2008 09:42 AM
fluteman
Mar 25, 2007 12:39 AM
bwilson4web
Feb 12, 2007 04:19 AM
