Which Generation DVD Nav does 2006 Hi Hy use?
I've got a 2006 Highlander Hybrid purchased in August 2005. My DVD version is 04.2. I've seen newer versions on eBay, and want to update. My question is: Does anyone know whether or not the 2006 Hi Hy uses the Gen 5 software? Is the latest update that I am looking for Gen 5, ver 7.1?
The override for Gen5 only works on a car that has a DVD with the number U30-U35 on it. If yours has that, then it is available at cruisin@live.com
Just an FYI. I spent to money on an upgraded DVD recently, and wish I had not. The return on investment was minimum at best. In some cases it was even a step back. For instance. it no longer properly locates my house address. It puts me off by app 1/2 a block. If you try to manually find the address it even has house numbers that do not exist on our street.
It was purchased from the dealer and they have confirmed it is not a set up issue. The new map that came on the DVD does not have house numbers correctly identified.
