Changing CVT fluid
Old Sep 11, 2019 | 11:27 AM
Robert F.'s Avatar
Default Re: Changing CVT fluid
Originally Posted by ukrkoz
So I have a question.
I was doing oil change on my 2012 HiHy and noticed that there is a hex plug in the very transmission belly bottom. Not on the side, as circled, right dead smack in the center of the housing flat bottom area. It's in the middle of rectangular :door" bolted to the housing and appears to be the lopwermost part of housing.
Yet, there is also a "drain" plug as described in the OP post.
So my question is - which one actually drain plug? As one I am inquiring about IS the lowest transmission housing point.
You are probably looking at the inverter coolant drain plug, it’s on the bottom of the transaxle PSD.
Old Mar 24, 2021 | 08:09 PM
Jaspher's Avatar
I just got mine done today at my friend’s shop. I have 40,000km on the odometer. If you don’t mind spending a little more for a fully synthetic fluid, Eneos Import ATF Model T-W is compatible with Toyota ATF-WS. Toyota Fluid is only semi-synthetic.
https://www.eneos.us/product/model-t-w/
HybridGates
Apr 8, 2017 04:42 PM
accent2010
Apr 7, 2017 05:47 AM
The Great Gazoo
Aug 31, 2013 06:14 PM
ahmadkq
Apr 4, 2010 07:22 AM
riksmg1
Jun 30, 2006 10:41 AM
