Can't change the time!
Old Nov 7, 2008 | 08:56 AM
Gordongirl's Avatar
Question Can't change the time!
I know this sounds crazy, and there must be some easy way, but without a manual, I've been searching through the menu system for days!
I can't figure out how the adjust the time, both for the Nav system and for the display!
Can anyone help?
Thanks!!
Old Nov 8, 2008 | 07:51 AM
WebG's Avatar
Default Re: Can't change the time!
did you press the "clock" button that appears up on your dashboard? Mine is next to the digital clock above the nav.
Old Nov 8, 2008 | 08:53 AM
rdalemercer's Avatar
Gordon girl,
It would help to know what year your Highlander is?
If it is a 2008 or newer, there is a "Disp" button on the right senter edge of the steering wheel (just above the "voice" button).
* Press and hold this button for 5 seconds and a menu will pop up on the small MFD screen just above the NAV screen.
* There are several options from which to choose, but "clock" should be the first one.
* Press and hold the "Disp" button again to go into setting the clock mode. You will be able to set the clock from that screen.
Please also point your browser to www.toyotaiguide.com to find out some additional information about the Highlander. It has an on-line manual that will step you through most of the things that you are wanting to discover. Although it's not the same as having a "paper" manual, it does provide a method to read up on your vehicle.
Go to "iGuide Resources"
Select "Owners Manual"
Select "Section 2: When Driving"
Go to page 193 for setting the clock.
Hope this helps.
Old Nov 10, 2008 | 08:20 AM
Gordongirl's Avatar
Wow, thank you! That's incredibly helpful!!
Of course, I should have posted that I have an '08 Highlander. I always forget those important little details!
Old Nov 10, 2008 | 12:11 PM
no worries.
Glad to be of some service.
Island Mariner
Jan 27, 2009 10:17 AM
Luke1975
May 21, 2008 11:14 AM
burningstar
Sep 10, 2007 03:48 PM
andybl
Toyota Highlander Hybrid
Aug 28, 2007 09:33 PM
TerrierMom
Introductions
Mar 30, 2006 10:03 AM
