Time to change Auto Tranny Fluid
Old Nov 28, 2008 | 05:20 PM
Island Mariner's Avatar
Default Time to change Auto Tranny Fluid
2006 Mercury Mariner Hybrid AWD, 30,500 miles.
Hi gang,
I'm planning to change my Auto Tranny fluid this weekend. I know some may think that's early, ridiculous, not needed, whatever. And yet... I'm still going to do it.
The manual specifies mercon fluid. Well, Ford has discontinued regular old mercon and has gone to the mercon V spec. I purchased Amsoil ATF, which is compatible with BOTH mercon and mercon V. So I think I'm ok on the mercon/mercon V issue.
My question is about the continuously variable transmission. The manual says don't get the motorcraft fluid for CVTs. Doesn't that seem weird seeing that my MMH has an eCVT? Is an eCVT so much different than a CVT and therefore takes regular old mercon instead ATF for CVTs? The amsoil atf says it isn't for CVTs either.
I guess that the manual is correct and even though I have an eCVT, I shouldn't use ATF for a CVT.
Anyone run across this problem/issue?
Thanks!
Island Mariner
Old Nov 28, 2008 | 05:27 PM
Default Re: Time to change Auto Tranny Fluid
NO--DON'T do it. You have a hybrid that uses an electronic CVT as transmission. The fluid in it is good for 100,000 miles.
Old Nov 28, 2008 | 06:13 PM
Thanks for the reply BillyK,
I'm aware that it has an eCVT. I'm fairly comfortable under the hood. I have the shop manual, which lays out the steps clearly and has the following specs for the fluid:
Material Item Specification MERCON® Multi-Purpose Automatic Transmission Fluid
XT-2-QDX (US); XT-2-LM12 (Canada) MERCON®
It appears that your concern is that the existing fluid is good for 100k and therefore I'm changing it early. I agree that I'm changing it early. I don't see any potential harm in changing it early as long as I have the correct fluid.
It seems stange to me that an eCVT tranny would NOT use an ATF designed for a CVT. Ours, to be clear, specifies regular old mercon - I just don't understand why.
I appreciate your concern, though.
Island Mariner
Old Nov 28, 2008 | 06:25 PM
Track down Mark Smith on this site as he is a professional mechanic and can provide up to date information.
Old Nov 29, 2008 | 12:52 AM
way2muchkc4u's Avatar
It's better for mother earth if you wait till 100,000 miles....
Old Nov 29, 2008 | 07:38 AM
twolostminds's Avatar
From: New Jersey. Land of high auto insurance and pollution.
Its a little early for me to be thinking about changing our tranny fluid. About 6 years early :O but I was also thinking about using either Amsoil or Royal Purple when I do the change. I think Island Mariner's biggest concern, and mine as well, is is it safe to use these other oils? With our old Hyundai if we didnt use the Hyundia or Mitsu branded ATF our warranty was voided.
Old Nov 29, 2008 | 08:30 AM
wwest's Avatar
The e/CVT has no frictional drive components such as clutches or bands, nor does it have the metal to metal "contact" drive belt as in an ACTUAL CVT.
Personally I wouldn't chance it at all but if you insist then I would suggest, STRONGLY suggest, not using ANY aftermarket product.
Old Nov 30, 2008 | 07:55 AM
MyPart's Avatar
Just my opinion but if you're going to change the fluid on something as specialized as the eCVT while still under the warranty period (and before the recommended interval), I'd only go with the same fluid used at the factory and recommended (in writing) by at least one Ford Service department manager/leader.
If something fails in your eCVT after you changed the fluid to something else, you're going to get a fight and you better have lots of data on your side. Ford will have thousands of eCVTs that have more miles on the stock fluid to point to. I would expect them to thoroughly inspect/diagnose the failure and your fluid will be on the short list.
I know that an ounce of prevention is worth a pound of cure but in this case I'd be very cautious.
Old Dec 3, 2008 | 07:36 AM
Mark E Smith's Avatar
Omnia Gloria Fugit
The fluid in the eCVT is for lubrication and cooling purposes only, for this reason I would change it every 30K. It has NO FILTER. The Amsoil ATF is a synthetic ATF fluid which is just fine for the eCVT. Like wwest stated there is no drive belt or metal belt like Honda and other CVTs have. The Mercon V fluid is a synthetic ATF, this is the primary difference between Mercon III and V. Ford wants to use the synthetic fluid to help extend the life of their normal auto transmissions and it is a much superior lubricant.
Old Dec 3, 2008 | 07:45 AM
Talking Re: Time to change Auto Tranny Fluid
Originally Posted by Mark E Smith
The fluid in the eCVT is for lubrication and cooling purposes only, for this reason I would change it every 30K......
Did we not all buy this hybrid to be greenER??!??
