Adding Cold Air Intake
Old Nov 28, 2007 | 10:04 PM
collegejester's Avatar
Default Adding Cold Air Intake
Has anybody looked at replacing the current air filter with a high capacity K&N cold air intake. Or maybe the FRAM Air Boost?
Old Dec 1, 2007 | 10:25 AM
Don R's Avatar
Default Re: Adding Cold Air Intake
The highlander Hybrid already has a very good cold air intake design receiving air from just under the front edge of the hood.
K&N makes a replacement air filter that fits the standard air box (part #K33332344). However, the K&N lower restriction filter element passes more abrasive particulate into the engine than the OEM pleated filter which may increase engine wear a bit. You must also be careful not to over oil them also as this could contaminate the MAF sensor which would cause engine performance problems.
billynjoanna
Jul 19, 2011 08:59 PM
billynjoanna
May 29, 2007 02:18 PM
rgx
May 8, 2006 07:27 PM
