2009 HiHy w/ P3011 - Battery Block 1 Becomes Weak
Old Sep 18, 2014 | 04:17 AM
MTL_HiHy's Avatar
Default Re: 2009 HiHy w/ P3011 - Battery Block 1 Becomes Weak
Originally Posted by philmcneal
i've considered the 06-07 body styles over the 08+ body styles due to their nicer pricing arrangements and performance (lighter body)
although the 08 are much nicer but pricier as well
The 06-07's were prone to having their inverters go south so keep that in mind when shopping as well.
That being said they can both be quite fuel efficient and body styles are definitely personal preference.
Old Sep 18, 2014 | 12:43 PM
philmcneal's Avatar
04 prius 350,000km
is that even if they had their inverters replaced after the recall?
Old Sep 19, 2014 | 05:41 AM
MTL_HiHy's Avatar
I'm not sure if that is the case of not because I've seen quite a few different failure modes and I don't know if they are all addressed at the time of the recall.
Old Oct 11, 2022 | 06:49 AM
Captain_Aads's Avatar
In case someone wants to see what I have been doing to solve this issue , it´s all in this thread on Priuschat (esp read pages 11-13 where I solved it).
http://priuschat.com/threads/gen-ii-...cement.125588/
I also suggest reading this thread as well since anyone working on a Toyota hybrid should have one of these too.
http://priuschat.com/threads/xp-home...ni-vci.137564/
So I recently got this error code on a Toyota Corolla hybrid and I did an OBD2 scan with the Dr.Prius app. Block one and Block five were showing high internal resistance.
So I took the battery out and it seemed like the contacts on the busbar sensing wires were very corroded as shown in the image.
I used a fine sand paper (No. 1000) and carefully cleaned off the corroded contacts and reinstalled the battery pack. Since then the internal resistance has dropped back to normal and I am no longer been the P3011 code.
Old Oct 11, 2022 | 10:11 AM
psron's Avatar
Good info. Did the EV mode performance improve?
Did you use any corrosion preventive coating to keep it from happening again?
Back in the day when we had corrosion problems on 12v battery posts, we'd do a thorough cleaning and neutralize the corrosion with baking soda and a tiny bit of water, rinse and dry, then before reconnecting - coat the posts and clamps with petroleum jelly. It's non-conductive, but displaces very easily so there's no insulative issues. It creates a moisture barrier that prevents future reoccurrance.
I still do this, even did it on my HiHy 12v battery... because it was corroding... now it stays clean.
Your post is a good reminder for me... I would like to try this on my HiHy traction battery pack... looks like a good weekend project.
Hi2u
Aug 30, 2014 04:16 PM
Ed Blown Vert
Apr 15, 2012 09:45 AM
mijohnst
Jul 24, 2010 06:20 AM
mijohnst
Mercury Mariner Hybrid
Jul 21, 2010 06:16 PM
bwilson4web
Dec 25, 2008 06:57 PM
