Wiper blade removal ??????
Old 12-02-2010, 01:46 PM
UWAdventurer's Avatar
Default Wiper blade removal ??????
OK, I have put many wiper blades on the TCH, but I now can't get the Goodyear Assurance blades to release. Thoughts anyone? I have tried everything except brute force. I don't want to break anything.
Old 12-02-2010, 04:07 PM
Default Re: Wiper blade removal ??????
Well, I had to physically break the clips that held the blades on to the arms. The removal tab would not disengage the blade from the arm. I'm baffled.
Old 12-02-2010, 04:42 PM
GeorgiaHybrid's Avatar
Don't force it, just get a bigger hammer....
I sometimes use a very small, thin bladed screwdriver to slide under and release the tab.
Old 12-02-2010, 05:40 PM
I tried the screwdriver also, could not get it to release. I know it sounds weird, but it would not release. Worked with it for 30 minutes, should have taken 30 seconds. Unbelievable.
Old 12-04-2010, 05:09 PM
ukrkoz's Avatar
i went through similar with my wife's lexus not so long ago, with conventional blades; and i can replace wipers blindfolded and with one arm tied behind my back.
i ended cutting them out with snips.
DO NOT apply any force to the arms though. you can bend them.
also, before you install the new ones, apply some anti-seize to the arm hook.
Old 12-05-2010, 01:10 PM
I actually had to break the plastic insert that fits into the bayonet. I have more to replace them with so it is no big deal. Don't really know what the problem was, never had that problem before.
kpdandjad
05-14-2011 07:41 AM
dburanich
03-12-2010 09:12 AM
icebluemariner
05-29-2009 11:35 AM
zimbop
03-26-2009 03:55 PM
Doug
03-05-2009 02:03 PM
