Where is the Hybrid control system ECU located?
Old Apr 21, 2010 | 06:59 AM
3prongpaul's Avatar
Default Where is the Hybrid control system ECU located?
Anyone out there know where the Hybrid Control system ECU is physically located on the car? The drawing below makes it look like it is in the engine room but it may be under the dash???
The ECU I'm looking for has two large connectors, C64 and A61. How can someone get access to these connectors?
(sorry, I don't have a TCH in front of me, I'm trying to help someone remotely with this...)
File Type: pdf
File Type: pdf
Old Apr 21, 2010 | 07:27 AM
GeorgiaHybrid's Avatar
Default Re: Where is the Hybrid control system ECU located?
It is bolted to the firewall underneath the brake fluid reservoir in the engine compartment.
Old Apr 21, 2010 | 07:30 AM
3prongpaul's Avatar
thanks!
is it hard to get to?
i.e. do you know what has to be removed to get access to the two ECU connectors?
Old Apr 21, 2010 | 08:12 AM
He can remove the brake fluid reservoir to make things a little easier but you can see it on the firewall. If they remove the reservoir, just pull it from the firewall but do not disconnect the line, just move it to the side. The hybrid ECU can than be unbolted from the firewall for easier access to the connectors.
Old Nov 8, 2015 | 06:57 PM
Ahmed Iqbal's Avatar
Default Re: Where is the hybrid control system ECU located?
Hey guys, do you know where ECM for camry 2009 hybrid located? Engine control management
Old Nov 9, 2015 | 05:13 PM
Read the first post.... That is the ECU that he asked about.
Ed28
Mar 23, 2020 01:50 PM
Billyk
Jun 5, 2010 07:51 AM
TonyK
Apr 11, 2010 11:13 AM
MagneticPearl06
Feb 17, 2006 09:14 AM
Jason
Hybrid & Related News
Jan 29, 2004 06:25 PM
