Whats that Servo Sound behind the Speedometer
Old Dec 26, 2007 | 08:56 PM
rburt07's Avatar
Default Whats that Servo Sound behind the Speedometer
Anybody know what the servo sound is behind the speedometer. I notice it occurs after shutting off the engine for the night. It seems to be delayed a few seconds after your press the power button for the engine to shut down.
The other I found after engine shutoff is a loud servo sound under the hood. Its coming from the metal ABS box where the brake lines connect to it. This is located next to the fender, behind the engine area of the passenger side headlamp. My guess is it may be some sort of fluid pressure bleed off.
Old Dec 26, 2007 | 10:06 PM
07CamHybrid's Avatar
Camry Freak
Default Re: Whats that Servo Sound behind the Speedometer
I'm not exactly sure what it is, but most of those sounds are normal. (At least according to the manual)
Old Dec 26, 2007 | 10:19 PM
rburt07's Avatar
Near everything on the car is all electric except maybe for the engine. I just enjoy knowing what each noise is although it's normal.
Old Dec 27, 2007 | 04:13 AM
schmidtj's Avatar
Keeping Toyota Solvent
Originally Posted by rburt07
Anybody know what the servo sound is behind the speedometer. I notice it occurs after shutting off the engine for the night. ...
Steering Wheel Lock solenoid?
Old Dec 27, 2007 | 04:22 AM
CJO2007CamryHyb's Avatar
The noise you hear under the hood is a relay, that turns on a vacuum pump, i believe. It usually comes on after 15-30 seconds after you turn the ignition off. I think it has to do with the gas tank vapor system. The reason that the TCH is an AT-PZEV is partly because the gas tank is sealed and will not allow any vapor to escape into the atmposhere. That system allows the TCH to eliminate the vapors........or substantially reduce them.
Old Dec 27, 2007 | 09:45 AM
SPL's Avatar
SPL
The electric motor noise coming from the steering column area when you open the driver's door after switching the car OFF is the steering column lock operating. The assorted electric motor noises from under the hood a minute or so after switching OFF is, I believe, the brake system de-pressurizing. The power (friction) brakes use a reservoir of pressurized hydraulic brake fluid, and this pressure is relieved shortly after switch-off. Fuel tank pressure checking doesn't occur until many hours (9 if I recall correctly) after switch-off.
Stan
Old Dec 27, 2007 | 10:47 PM
rburt07's Avatar
Your right about the dash servo. I started the car and put it in gear. The servo noise came on and I saw the steering wheel move about 1 inch. So now I now the servo behind the speedometer is locking and unlocking the steering wheel.
corndog
Jun 11, 2016 02:17 PM
angelai
Apr 11, 2010 02:19 PM
Sorsha
Apr 7, 2010 01:56 PM
brick
Mar 8, 2008 11:51 AM
Robert_Detjen
Oct 16, 2005 06:08 PM
