What RPM does your ICE rev to?
Old Feb 24, 2013 | 04:28 PM
Ron AKA's Avatar
Default What RPM does your ICE rev to?
For those that have a Scangauge or equivalent, I am curious as to what rpm your ICE runs at, relative to road speed, acceleration, and what is displayed by the ECO gauge? The graph below is a map of engine efficiency based on torque and rpm. It is for a Prius but I would expect the Camry ICE to be similar. The red line is the said to be the desired operating point for the hybrid synergy drive, depending on power desired from the ICE. What you should see as you ask for more torque (acceleration) is the rpm stay constant at about 1,100 rpm. Then at some point of higher acceleration the rpm will start to increase. Maximum efficiency is going to be reached when the rpm gets up to the 3000 rpm range.
I'm curious as to what it takes to do that when you accelerate away from a stop light up to the speed limit, or up to merge speed on an on ramp?
chaunceyjb
Mar 2, 2011 01:51 PM
nash
Mar 5, 2008 03:57 PM
Roy
Sep 9, 2007 05:20 PM
Orcrone
Sep 20, 2006 11:39 AM
spiff72
Sep 15, 2006 11:07 AM
