What is the B shift gear?
Old Dec 12, 2006 | 03:19 PM
Jimmy12's Avatar
Default What is the B shift gear?
Hi ,
I am curious to know what that B is after D for drive?
I once shifted to B from D for drive in highway and the I felt the car heavy .
Mine is camry hybrid!
Old Dec 12, 2006 | 03:51 PM
jay_man2's Avatar
Beyond AM. Beyond FM.
Default Re: What is the B shift gear?
You can put the car in B to use engine braking when going downhill, so you don't have to use the brake pedal as much. There's a downhill grade on my way home from my parents where I'd shift into 2nd with my last car. That caused the transmission to stay in 2nd gear, and use engine braking so I wouldn't have to ride the brake pedal down that hill. Same concept here with the CVT transmission, from what I read in the owner's manual.
Old Dec 12, 2006 | 04:22 PM
skywagon's Avatar
Originally Posted by Jimmy12
Hi ,
Grade retard!!!
Old Dec 13, 2006 | 02:58 PM
flopshot's Avatar
Hi ,
A cynical poster would reply RTFM.
I will suggest that you do a search for "engine braking" since there has been much discussion in the past on this topic, and the pros/cons of using engine braking.
Old Dec 13, 2006 | 04:49 PM
gaijin42's Avatar
I posted a big write up of B mode on my blog a few months ago. Check it out here.
http://geekswithblogs.net/gaijin42/a..._failure_.aspx
Old Dec 13, 2006 | 05:13 PM
Jimmy12's Avatar
Gaijin,
Thank You Very Much For The Very Clear Information And Instuction About The (b) Shift Gear!
It Really Helps!
Skywagon, Hey I Don't Apprecite You Calling Me A Retard! Asking Question Is Now Allowed Here Or What?
Old Dec 13, 2006 | 05:17 PM
gaijin42's Avatar
Jimmy, I'm glad you found the information helpful. By the way, the previous poster wasn't calling you a retard. He was saying the purpose of the B gear is for "grade retard" or "to slow you on a grade"
Old Dec 13, 2006 | 05:21 PM
Jimmy12's Avatar
Thanks For Clarifying!
Apology For Skywagon!
Old Dec 13, 2006 | 06:29 PM
skywagon's Avatar
Hey Jimmy no problem, I guess i should have made it more clear. I am dating myself here but some of the very old General Motors cars in the 60's had what they called a Turbo Glide and this transmission had a GR on the indicator which stood for grade retard. The Power glide did not have this feature. SK
Old Dec 13, 2006 | 08:56 PM
Sooty's Avatar
...and here I am thinking that's why I failed Grade 5.
Geez ya lern summit evry day.
Geckoboy
Jul 13, 2013 08:52 AM
Sky Blue
Aug 15, 2008 12:36 AM
ovals49
Jan 15, 2007 12:24 PM
Jason
May 16, 2005 05:16 PM
Jason
Hybrid & Related News
May 22, 2004 01:30 PM
