Water pump replacement
Old Aug 7, 2009 | 10:17 AM
jared125's Avatar
Default Re: Water pump replacement
My 07 TCH was made in Kentucky.
Old Aug 7, 2009 | 01:10 PM
rburt07's Avatar
Originally Posted by David Price
Question: are the TCHs that have the water pump issue made in the USA or Japan?
I read in the forms it was the the 2007 models made in Japan. My 2007 is from the Kentucky plant. I called our local toyota service and they said mine was not on the recall list.
Old Aug 7, 2009 | 04:11 PM
David Price's Avatar
Happy 07 TCH Owner
I'm not aware of a recall list for the water pump, is ther one? My wife's TCH is an 07 model made in Japan.
Old Aug 9, 2009 | 03:09 PM
bmgoodman's Avatar
Mine is from Japan.
Old Aug 10, 2009 | 03:09 AM
rburt07's Avatar
The steering rack was the only recall I can remember on the TCH.
Old Sep 16, 2009 | 03:45 PM
bajer's Avatar
I don't own a hybrid camry. But just wanted to post that my Japanese built 2007 4-cylinder camry needed the water pump changed due to a leak found during a routine oil change. It was bought around April 2006 and has around 41000 miles. It is covered under the powertrain warrenty, so 5 years/60k.
Old Oct 19, 2009 | 12:49 PM
  #27
Mainer's Avatar
Along for the ride.....
Add mine to the list of water pump leaks. It's a 2007 Japan built Camry Hybrid. 58K miles so just made it under powertrain warranty. I'm sensing a recall.
Old Oct 19, 2009 | 04:38 PM
  #28
Mainer's Avatar
I asked the service advisor if he's seen other water pumps being replaced and he said several. He said not just Camrys either - Corollas too.
Old Feb 6, 2010 | 09:56 PM
  #29
FL07THC's Avatar
Mine was leaking at 68,000 miles. Replaced under extended warranty. I hve also had my steering rack replaced and it is now in the shop for blown JBL amp.
Old Feb 8, 2010 | 11:48 AM
  #30
cmartinez95's Avatar
Hmmm, I'm at 55k on my Japan Built 07. I guess I'll be inspecting everything real good at my next oil change. If I see anything that looks like residue from coolant I'll be seeing my local dealer before the 60k mark.
