Warning to XM radio owners
Warning to xm owners who have moved your antenna to the outside of the car. I did this when I had my windows tinted in April 2007. Last month(may 08) I noticed that the satellite signal was starting to drop off in places that I never had a problem before but just kind of ignored it until one day no signal at all.I removed the back plate(3 small screws)and the inside had rusted.They are not water tight.Tried to find a new one on the internet but found out from a online retailer(xmfanstore.com) that you have to buy it from Toyota as the plug is exclusive to Toyotas parts.Ordered one to the tune of $57.00. OUCH. This time I'm going to fill the antenna with clear silicon before installing.If anyone is having signal problems you might want to check it out.
Re: Warning to XM radio owners
Tinted 35% in the rear and I have noticed no loss in signal.
There are two types of antenna connectors: the tiny 'coaxial' type and the 'two prong' type. The freestanding kits, like home kits and car kits to adapt portable units use the coaxial type, while the permanent mount kits used in cars to connect to the various in-dash units ( not Toyota specifically) use the other. These are usually a plastic square shell, colored light green or pink, that fit into the appropriate jack on the base unit.
Since there are so many of these type kits out there, it is fairly easy to get a replacement antenna. I see them locally at Fry's Electronics for $39.95. You might try Googling for a local or mail order source.
Thank you Radiotek for responding.The plug for my unit is light gray and square inside. I would love to find an antenna that is designed for roof top installation and weather proof.Before I put the new antenna back on my roof (I used the 3m tape) I filled the inside of the antenna with silicon.I wasnt sure if the silicon would damage the electronics but apparently not as its working just fine.
Just purchased an 09 TCH got it last week drove it around XM worked great, dealer had promised to throw in the tint for free but had to schedule it later. Got it tinted 3 days ago (rear window 35%) and XM drops out all the time sometimes forever. My antenna is on the inside rear deck passenger side. Dealer says they can move it outside but they are going to have to order new antenna (rated for exterior mounting) should be in Tuesday of next week. They said i could have it mounted anywhere i wanted. My preliminary decision is to mount it on the rear trunk lid center. I've have a factory mounted XM system in a GMC vehicle never had a problem and another in a third SUV that is dash mount with antenna front center inside of vehicle no problems there either. Will post resluts
Hey MAC,
Before you move your antenna to outside, give the film 2 weeks to cure. It may get the signal back. I vent with my XM signal thru HELL, I replaced 2 sets of film before I moved the antenna outside, and the great place for it on the glass because the antenna is black. If your dealer will replace your antenna with exterior grade please find out the part number, because I moved my original antenna, and I think I may loose signal in the future, here in California not much rain, but eventually it may go bad. Thanks, Tim
Tim,
When it comes in I'll get the part number for you, I'm going to go with the flow as the dealership has really gone above and beyond to keep us happy we had a few minor issues and they are doing whatever they can to remedy them. This is the only real issue left and only popped up after they installed the tint (a freebie). I live in Southwest Texas so the tint is a must. Rain comes a few times a year here but when it rains it pours, so I'm gonna let them do what they must. They alwasy give us an XLE as a loaner anyway (+gas), so it hasn't become a headache yet.
