Walking away with the FOB
Old Jan 25, 2007 | 01:56 PM
schmidtj's Avatar
Keeping Toyota Solvent
Default Re: Walking away with the FOB
Originally Posted by Geckoboy
I haven't tried this yet, but I'm guessing you could lock the FOB in the trunk. Consider this scenario:
1) FOB in your shirt pocket, no other FOBS inside the car. You park your car, get out, close the door and lock the car via the button on the door handle
2) You walk over to the trunk, open it, bend over to retrieve something -- now the FOB accidentally slips out of your shirt pocket and into the trunk without you knowing..
3) you close the trunk and go on about your business..
Now.. will the TCH warn you that the FOB is inside the car/trunk? Will it allow the trunk to be closed? Will it unlock the doors when you close the trunk with the FOB in it?
I just thought about this scenario. I may give it a try later tonight.
<speculation mode>
I bet you can close and lock the trunk. BUT I also think you'd be able to reopen the trunk by pressing the latch button. Reason being there is only one trunk transmitter and I don't think it can distinguish if the fob is inside our outside. Unlike the separate zone for handles, and passenger compartment.
</speculaton mode>
Old Jan 25, 2007 | 01:58 PM
Geckoboy's Avatar
If that's true, that would be bad. Often times my wife would put her purse in the trunk to avoid tempting anyone to break the door windows should she leave it in the seat. If her key FOB was in her purse, then anyone (who knew about it) could simply walk up to the car and unlock the trunk.
Originally Posted by schmidtj
<speculation mode>
</speculaton mode>
Old Jan 25, 2007 | 02:07 PM
Geckoboy's Avatar
Well well, just looking at the car manual answers my question:
If the trunk is closed with the key left inthe trunk when all side doors are locked, a beep will sound continuously for 2 seconds. You can open the trunk pushing the trunk opener switch without carrying another key. However, in some instances, the beep may not sound when the trunk is closed depending on the location of the key in the trunk. In addition, when the doors are open or unlocked, the beep may not sound when the trunk is closed. When closing the trunk, make sure that the key is not left in it.
So you have 2 seconds to open and retrieve the key. Otherwise you call AAA (can they even open the car door in the TCH) or call whoever has access to the 2nd FOB.
Old Jan 25, 2007 | 04:19 PM
schmidtj's Avatar
Nope that's not how it worked (for me).
I just tried it and yes it gave me 1 long beep then silence. I waited 60 seconds and pressed the trunk release button. No other fob was within 25 feet of the car and the trunk lid opened.
Old Jan 25, 2007 | 05:01 PM
OmegaOmega's Avatar
Confirmed. I just tried it and the trunk opened for me when i pressed and held the latch release pad.
Old Jan 26, 2007 | 04:35 AM
klynch's Avatar
I think the manual is saying that the car will beep for 2 seconds. You have both proven that you have longer to actually open the trunk--the question is, how much longer do you have until you can no longer open the trunk without a FOB?
Old Jan 26, 2007 | 04:47 AM
  #27
schmidtj's Avatar
Forever. Or until the system can no longer detect the presence of the fob in the trunk. What is the shelf life of the fob battery? What is the temperature of the trunk?
Old Jan 26, 2007 | 06:53 AM
  #28
Big-Foot's Avatar
Currency-to-hydrocarbons
I wonder..
I wonder if you can put the spare FOB in the trunk and then lock the car with a double-press of the door button. When pushing the button twice - I was unable to unlock the car via proximity detection - I actually had to press the UNLOCK button on my FOB.
Old Jan 26, 2007 | 09:48 AM
  #29
bobbywalnuts's Avatar
Someone told me. . . haven't tried. . That the rf signal is in that little key found in the FOB. They said that if you loose your FOB call someone who has one to your car and they can start the car with a cell phone to cell phone call (place the rf key next to the microphone). Sounds like a bunch of bunk. . myth or fact?
Old Jan 26, 2007 | 10:19 AM
  #30
OmegaOmega's Avatar
Oh Yes! And if I connect my bluetooth I can also pick up interstellar chatter between advanced civilizations.
