Vais tech iPod integration experience/feedback
Old May 23, 2008 | 01:28 PM
  #31
mlarma's Avatar
TCH Obsessive
Default Re: Vais tech iPod integration experience/feedback
We have the Toyota one and it works fine from an audio perspective. however, browsing songs and things that would be nice to do, it just won't do. If you define playlists, it is a bit better. W/O them and with bad/no tags, it is gonna suck rocks.
Mark
Old May 25, 2008 | 06:20 AM
  #32
mikieboyblue's Avatar
Originally Posted by ToutSuite
The new firmware is definitely an improvement. Now you're presented with six discs, as if you were looking a six disc changer. Each disc corresponds to a different way of browsing (and this may not be the correct order): playlist, artist, album, genre, audiobook, and podcast. Once you select a "disc," you then browse just as you did previously through a playlist - up and down arrows to go through folders and songs one at a time. The discs themselves aren't labeled, and instead you get a text box which pops up when you select one, telling which mode you're in ("Artist," "Album," etc.). This box disappears after a few seconds.
Does this mean you must still use a playlist even for the artists? Or does the artist 'disc' read all songs on your iPod and create a virtual playlist -- just like when you use the actual iPod to search your songs by artist?
Old May 25, 2008 | 11:39 AM
  #33
ToutSuite's Avatar
When you click on the artist 'disc' you can then scroll through the artists on your iPod, just as you would if you were using the actual iPod to browse. If you stop on an artist, it will begin playing that artist's songs in order (or random, if you have that selected). It will remain on that artist until you decide to move to another artist.
Old May 25, 2008 | 01:26 PM
  #34
coolshock1's Avatar
Driving in stealth mode
This is encouraging. I can't wait to get my update adapter so I can get the updated firmware.
Tout what are impressions of the new firmware now vs the old firmware?
Old May 26, 2008 | 05:03 PM
  #35
ToutSuite's Avatar
Well, it's definitely an improvement over the previous firmware. But I'm not an ideal candidate to judge, as I'm only using an 8GB iPhone with it, with a single music playlist (plus some audiobook playlists). In fact, I still find it somewhat easier to use the cover flow view on my iPhone when choosing songs than scrolling through endless lists on the Vais interface.
I would say if I was using a regular iPod tucked away in the glove compartment, I'd find this new firmware a huge improvement which makes the Vais that much more enjoyable to use.
Old May 27, 2008 | 06:36 AM
  #36
That's good to know. Thank you.
I rarely use the song list on the iPod to find something, usually it is the artist list. You cannot view the songs in the artist list correct?
Also, what makes the VAIS worth the money of the other alternatives?
I need to update my other thread which is a poor-man's attempt to organize all this...just so little time!
Old May 27, 2008 | 07:34 AM
  #37
coolshock1's Avatar
The main justification for cost seems to be the ability to update\grade the firmware of the unit allowing for increased capabilities without having to buy a new unit.
Old May 27, 2008 | 08:09 AM
  #38
coolshock1's Avatar
I just went and reviewed the post from BackupGuy again and found some differences. With the device he got he stated that you couldn't switch playlists while moving. The Vais does not have this issue. Also the search features are now the same due to the firmware upgrade. The VAIS unit will allow you to auto-override the "I agree" screen on the NAV unit. After programming the setting 1 time it will over ride it after 5 seconds. The setting only has to be made during the initial setup and nothing afterwards.
tsvikabp
Lexus GS 450h
Jul 13, 2011 03:41 PM
ntguru
Aug 10, 2007 08:15 PM
Rathany
Dec 22, 2006 03:21 PM
spiff72
Nov 22, 2006 11:30 PM
