Trunk will not open 2009
Old Apr 7, 2011 | 11:56 PM
modeladay's Avatar
Default Trunk will not open 2009
Well I finally had to replace the battery in the fob and now it will not open the trunk. Also the lever on the inside of the car will not open it ether the only way to open the trunk is to use the key it self. Is there a way to reprogram the fob so it will once again have this feature.
many thanks
dusty
Old Apr 8, 2011 | 12:57 AM
modeladay's Avatar
Default Re: Trunk will not open 2009
yes everything else works, second fob died in a desk drawer Just prior to replacing the battery it worked,
thanks
dusty
Old Apr 8, 2011 | 04:58 AM
lvw's Avatar
lvw
In your place I would take the fob apart again and reassemble it. It's possible that you didn't put it together just right, and the trunk button is jammed. I *know* that's possible...
Larry Van Wormer
Old Apr 8, 2011 | 06:39 AM
KC Rusty's Avatar
I had the same issue way back when. Turned out to be my issue. Look at the actual lock on the trunk. If the slot is vertical, I believe you have the trunk in valet mode. in this mode the fob or inside release won't work. Take your fob key and turn the lock to horizontal and your will find all is well in the world. Cost me a trip to the dealer to find this on.. (If the slot is horizontal - turn it vertical -- memory is not clear)
Old Apr 8, 2011 | 12:22 PM
SteveHansen's Avatar
Pragmatist
It doesn't seem to be in the owners manual that I can find.
I did find the following in the "Emergency Response Guide":
"Inserting the hidden metal cut key in trunk lock and turning clockwise unlocks the trunk lid. For valet service, turning the metal cut key counter clockwise locks and deactivates the smart key and release lever from opening the trunk."
Old Apr 14, 2011 | 05:59 PM
modeladay's Avatar
Good lord, thank you, thank you, I could not find this any where
dusty
Old Apr 14, 2011 | 06:20 PM
KC Rusty's Avatar
So I guess that fixed it... If so - glad to be of assistance
Old Apr 17, 2011 | 05:09 AM
dg370's Avatar
I have attached the manual page for the Luggage Security System.
File Type: pdf
hardcopy
May 22, 2015 04:54 PM
Ahab
Sep 7, 2009 03:09 PM
haroldo
Aug 6, 2008 12:57 PM
David Price
Feb 18, 2008 06:52 AM
leepark
Nov 28, 2007 07:33 AM
