Toyota's current problem's vs Ford's past...
In comparison to Toyota's current problems. I want to bring up the recovery of Ford. They would have a near full recovery if the economy was back to normal.
This is highlights of what happened to Ford and Firestone and includes death estimate and injury numbers.
From Wikipedia:
The Ford Explorer was first offered for sale in March 1990. Ford internal documents show the company engineers recommended changes to the vehicle design after it rolled over in company tests prior to introduction, but other than a few minor changes, the suspension and track width were not changed. Instead, Ford, which sets the specifications for the manufacture of its tires, decided to remove air from the tires, lowering the recommended psi to 26. The maximum pressure stamped into the sidewall of the tire was 35psi; however tires should only be inflated to the pressure listed by the vehicle's manufacturer.
The failures all involved tread separation—the tread peeling off followed often by tire disintegration. If that happened, and the vehicle was running at speed, there was a high likelihood of the vehicle leaving the road and rolling over. Many rollovers cause serious injury and even death; it has been estimated that over 250 deaths and more than 3,000 serious injuries resulted from these failures.
Ford and Firestone have both blamed the other for the failures, which has led to the severing of relations between the two companies. Firestone has claimed that they have found no faults in design nor manufacture, and that failures have been caused by Ford's recommended tire pressure being too low and the Explorer's design. Ford, meanwhile, point out that Goodyear tires to the same specification have a spotless safety record when installed on the Explorer, although an extra liner was included into the Goodyear design after recommendations to that effect were made to Ford. Firestone included an extra liner in its product and this was then also used to replace tires on Ford Explorers.
Many outside observers tend towards blaming both parties; Firestone's tires being prone to tread separation and failure, and the SUVs being especially prone to rolling over if a tire fails at speed compared to other vehicles. A subsequent NHTSA investigation of real world accident data showed that the SUVs in question were no more likely to roll over than any other SUV.
From Wikipedia:
Re: Toyota's current problem's vs Ford's past...
1. toyota current problems vs Fords SUV rollover past. It's amazing that Ford recovered with Firestone after so many deaths.
2. I wanted to compare the 'stocks' in a seperate header, showing that toyota is a strong company.
3.Current News of the Ford Fusion Hybrid is also having braking issues similar to the Prius.
rrrrrroger
Off Topic
01-29-2008 11:41 AM
Mr. Kite
11-17-2006 10:09 PM
