Toyota Stuck Throttle Recall Fix
Old Oct 2, 2009 | 10:58 PM
rburt07's Avatar
Default Toyota Stuck Throttle Recall Fix
My wife saw on the news that Toyota may decide on flashing the ECU.
The flash adds slightly to the programming. If the ECU sees the throttle accelerating with the brakes applied at the same time, the ECU would instantly release the throttle.
Old Oct 3, 2009 | 05:19 AM
skywagon's Avatar
Default Re: Toyota Stuck Throttle Recall Fix
I found similar from this online highlight news report.
Be real carefull of letting them flash the ECU, had that done to two differant vehicals and milage went into the chitter!!!!!!
Old Oct 3, 2009 | 12:13 PM
rburt07's Avatar
Could be when they flashed to update your ecu they made more then the one change. Some engine updates can change the timing, rpm where the transmission shifts and etc. That was my experience with Ford.
I had a 2006 Ford Five Hundred with a 6-speed automatic. It had some other problem but while they had it they did a tsb on the transmission. I then shifted at lower rpm which helped get better gas mileage. Although about half of what my TCH is getting now. Still not bad for a full sized Ford. I traded it due to continuing various other problems.
Old Oct 3, 2009 | 09:23 PM
duanerw's Avatar
old fart
There is no recall but they advise not to use any floor mat until the investigation is complete and they find the cause.
The Lexus involved in the accident had two sets of floor mats and i beleive the top ones were all weather and not made for that lexus.The lexus was a loaner from the dealership.The troopers wife was driving and may not have known to hold down on the start button for three seconds to shut it off.I didnt know that till i read the report at my dealership today.they are also looking into possible electrical problems.
Old Oct 3, 2009 | 09:47 PM
rburt07's Avatar
This is from the Toyota USA Newsroom.
http://pressroom.toyota.com/pr/tms/t...610_p229517417
backbob
Aug 31, 2011 11:09 AM
beseler
Jun 5, 2008 10:57 AM
Bemanix88
Apr 15, 2007 12:36 PM
Chilly
Toyota Highlander Hybrid
Apr 2, 2006 05:17 PM
