Toyota iPod Integration Kit??
Old Jan 14, 2008 | 09:26 PM
Dang's Avatar
Default Re: Toyota iPod Integration Kit??
I don't think so.
The iPod will pause when you disconnect the headphones, but not when you disconnect power. I think you'd have to unplug it.
Of course the adapters mentioned above can pause it and charge it, but I assume you are just talking about the aux adapter.
By the way, I've ordered hte scosche adapter. It emulates a sat connection, and seems to do more than the CD based vaistech one.
Later!
Dang
Old Jan 14, 2008 | 10:08 PM
mikieboyblue's Avatar
Originally Posted by Dang
I don't think so.
Later!
Dang
As long s the scosche one can both charge and allow me to pause all is good. Basically, when I leave the car, I simply pause the iPod. I would much rather hit a button the NAV than find the place on the iPod. I did find a pinout of the iPod and it looks like you can control the on/off functionality but I need to get a plug to use.
Old Jan 16, 2008 | 03:35 PM
jbollt's Avatar
I don't think so.
Later!
Dang
Dang: Be sure to let us know when you get it and how it works! I am still trying to justify the money. (Or realy, trying to figure out how to justify spending the $150-$200 to my wife!)
Added: BTW, my ipod pauses and then goes to sleep after the car is shut off when using the Belkin ipod power adaptor which plugs into the bottom port on the ipod. It then "wakes up" when I start the car, and I have to push play on the ipod, and it resumes playing from where it left off.
Old Jan 17, 2008 | 10:50 AM
Wavern's Avatar
I'll be getting the Scosche AXIPTA in the next few days if anyone is interested in how it works.
http://www.scosche.com/products/sfID...productID/1476
Old Jan 17, 2008 | 12:18 PM
Please let us know how the install goes and what features you get. If you are doing the install and don't mind taking pictures of how you took things apart or where you put them I know at least one person (me) would appreciate it.
Old Jan 18, 2008 | 10:37 AM
Wavern's Avatar
Well the part isn't getting here until Monday so it'll be sometime next week. I'm also going to attempt to build a pulse generator that'll trick the OEM nav unit into thinking that I'm an adult and should be able to interact with it while the car is moving. Should be able to install both at the same time.
Old Jan 18, 2008 | 10:44 AM
Awesome. Yeah, I want to get it to play DVD movies. I need to figure out how.
Old Jan 18, 2008 | 10:47 AM
Wavern's Avatar
The VAIS folks have a device that'll play videos off the ipod on the NAV screen, though a youtube search of VAIS shows that the unit only shows video with the parking break engaged .... Didn't like that.
Old Jan 18, 2008 | 10:57 AM
Yeah, that's dumb. I think someone posted about using the back up cam system as a video playing mechanism...I'll have to find it again.
Old Jan 18, 2008 | 03:01 PM
Bobby Soprano's Avatar
That would be nice. That's the most annoying thing about some factory NAV systems IMO. My 2007 Infiniti QX56 is the same deal. There is a hack for the Infiniti which involves cutting a wire and installing a switch. No way I'm attempting that until my warranty is up.
