Touch up paint application.
Old Apr 22, 2007 | 12:34 PM
AKM's Avatar
AKM
Somewhat hard driver
Default Touch up paint application.
For those of you that have applied touch paints what works the best for you, paint and a brush or the touch up pens?
Thanks.
Old Apr 22, 2007 | 01:55 PM
kris's Avatar
Default Re: Touch up paint application.
Toothpick method.
Old Apr 22, 2007 | 03:55 PM
jay_man2's Avatar
Beyond AM. Beyond FM.
The Toyota paints now let you choose between brush and pen method. I use the pen, as it's like the toothpick method that kris mentioned. If your only choice of applicator with the paint you buy is a brush, use a toothpick instead of the brush.
I've had good results with the pen applicator on a Toyota OEM tube of paint.
Old Apr 23, 2007 | 11:41 AM
flopshot's Avatar
Thanks.
I tried the touch-up pen from PaintScratch.com, and went back to the toothpick method just like Kris.
Old Apr 23, 2007 | 12:48 PM
abowles's Avatar
The toothpick method will give you the best results because
you can get a much smaller portion of paint applied directly to the
problem area and with much finer control. This is regardless of how
the paint is purchased from Toyota. I have applied just enough to have a slightly raised bubble of paint. When it dries it will be very close to the
original paint depth. A deeper gouge might require more than one application. Good luck.
Old Apr 23, 2007 | 07:19 PM
AKM's Avatar
AKM
Thanks guys.
Bottle and tooth pick sounds good.
GeekGal
Oct 1, 2008 12:16 PM
trip221
Jun 12, 2008 08:47 PM
Anahymbrid
May 20, 2007 09:22 AM
dogzen
Jan 20, 2007 09:24 AM
pquig
Jul 7, 2006 08:44 PM
