TIRE PRESSURE MONITOR?
Old Aug 24, 2006 | 11:37 AM
CrisCross's Avatar
Default TIRE PRESSURE MONITOR?
Your TCH has this feature? How do you feel about it? Does it helps you or bothers you?
Old Aug 24, 2006 | 11:48 AM
Orcrone's Avatar
Default Re: TIRE PRESSURE MONITOR?
I haven't had it come on yet. There's nothing intrusive about it and if a tire loses a fair amount of pressure I think it's a good thing to have. You're much more likely to have a blowout with an underinflated tire as it doesn't handle heat build up as well.
Old Aug 24, 2006 | 12:44 PM
jbollt's Avatar
I'm glad i have it. One week after delivery, i picked up a screw in the RR tire. I wouldn't have known it, and might have ruined the tire from the slow leak, if the TPM hadn't warned me of a low tire. (All others were at 35, this one was at 29). It certainly wasn't low enough ot notice it visually! I was able to have the tire repaired (free at Discount Tires) and potentially saved myself from having to buy a new tire, or worse, a safety issue from driving on an extremely low tire.
Old Aug 24, 2006 | 12:58 PM
nash's Avatar
I've reset mine to monitor the pressures I'm running (42/40 front/rear)
Page 179: Set parking brake, Power ON then press the Reset switch in the glovebox for a few seconds until your tire pressure icon on the main gauge display slowly flashes three times.
I've lost a tire before from running flat. A nail caused a moderate leak and the tire self destructed before I knew there was a problem... I really like that the TCH will warn me before a tire is dangerously low. Great safety feature
Old Aug 24, 2006 | 01:54 PM
schmidtj's Avatar
Keeping Toyota Solvent
Does that affect your breaking distances adversely?
Old Aug 24, 2006 | 02:04 PM
nash's Avatar
Not that I can tell. Braking and cornering seem quite good with this pressure.
I had a dog dart out in front of the car and did a panic stop. I was very impressed with how fast the TCH stopped. The tires squealed for a split second, and the ABS kicked in and stopped. I was going about 35mph at the time.
Oh, the dog was fine!
If I had been driving my truck, it would have been ugly.
Old Aug 24, 2006 | 03:27 PM
kluken's Avatar
I like having a TPMS, but I prefer a direct read out system, liek my TL had, I woudl page through their MID and once page woudl be each tire's exact pressure. The Camry is a percentage drop and to date I have yet to get an answer from Toyota on what the drop needs to be to trigger it. Also with everyone pumping up their tires over factory spec is everyone resetting their TPMS, the procedure is in the book. I set my pressure to 36 PIS and reset the TPMS, but if it is true that it won't trigger until liek a 20% drop well that is 29 PSI which to me is unacceptable I want to know sooner, but given that I usually check my tires every 2 weeks or so I guess it will do.
Old Aug 25, 2006 | 08:19 AM
Ladybug's Avatar
Is this a standard feature in the TCH? I didn't even know I had it. Can you get it to display what the pressure is currently set to?
Old Aug 25, 2006 | 08:26 AM
Orcrone's Avatar
Yes it's a standard feature. It just lights up an icon on your dash when a tire's pressure drops a certain number of psi below the last calibration. As far as I know there's no way to display the pressure.
Old Aug 25, 2006 | 08:30 AM
schmidtj's Avatar
It is standard.
See attached for some light reading on how it all works.
J
File Type: pdf
