Tap power from fuse box?
Old Sep 3, 2008 | 03:47 AM
bwilson4web's Avatar
Engineering first
Default Re: Tap power from fuse box?
My apologies for posting to this thread. I was afraid it was one of those hydrogen generator systems and didn't realize the lighting kit came with a wiring harness. Having once had a wire begin shorting back to a battery, I had to yank the battery terminal off, I'm very cautious about car wiring.
One last suggestion is to feel the wires or use an IR thermometer to check the wires and system once it is installed. It is so much easier to deal with a hot wire than a burnt one.
GOOD LUCK!
Bob Wilson
Old Sep 3, 2008 | 04:48 AM
mikieboyblue's Avatar
GOOD LUCK!
Bob Wilson
Bob, not a problem! Hydrogen generator systems!! Crazy!
Honestly though, I learned a few things from your posts. Thank you. And I didn't think to feel the wires once everything was set up...that's a good idea...(I don't have an IR thermometer...).
Thanks,
Mike
Old Aug 16, 2022 | 10:09 AM
Barrettnevets's Avatar
Bob in the hybrid battery junction box relay module in my Camry hybrid there is this fuse that is filled with tiny stones and next to it are two empty slots that look like they could be used to power an investor or other device. Are you familiar with the junction box slots I am referring to, and do you know what those other empty slots are for?
Based on this table:
http://www.powerstream.com/Wire_Size.htm
A 12 GA wire should work fine. The initial 20 A. is well within the limits of chassis wiring and the sustained 7.2 A. gives plenty of sustained power margin. However, you won't need a ground wire to the battery. Just find a good electrical ground in the engine compartment.
Sorry but I don't know enough about the Camry wiring and chassis to offer practical advice on routing. I'd suggest looking for the repair manuals with electrical diagram. BTW, that might give you a pointer to the 12 VDC power source from the inverter. Whether or not it can be tapped, the diagram and maintenance manual would be the road map. Just make sure you put a good, inline fuse close to the source.
Bob Wilson
kinger44
10
Mar 25, 2016 04:19 PM
talljetman2
Feb 16, 2009 12:56 PM
cephraim
Sep 26, 2008 10:08 AM
carolinacamry
Jun 11, 2008 05:36 PM
JJanney
Jun 8, 2007 02:06 PM
