Switchover from electric to gas...
Old Aug 29, 2006 | 09:45 PM
belbe's Avatar
Question Switchover from electric to gas...
A friend of my husband has a Prius and says that the Camry should/will have a speed above which the engine is forced to run by the controller software. On the Prius it's 42 mph. Above that speed you just have a gas engine car and you can drive it any way you want. All the electric only operation will be below that speed.
So, Hybrid Gurus, is this the way it is?
FYI..his Prius is the very first year that came out...
Old Aug 30, 2006 | 04:21 AM
Orcrone's Avatar
Default Re: Switchover from electric to gas...
Above 42 mph you will also be using the ICE with the Camry. But don't think of it as a regular car above that speed. Like the Prius it uses an Atkinson cycle engine which is more efficient than a regular (Otto cycle) engine. Although the ICE will always be spinning there will be times that it won't be driving the wheels like when you're going downhill. Under heavy load the electric motors can kick in to assist the engine.
I find that at 60 mph on level ground I'm getting approximately 45 mpg according to the instantaneous mpg gauge. Try that in a non-hybrid mid-size car weighing 3600 pounds.
Old Aug 30, 2006 | 04:33 AM
schmidtj's Avatar
Keeping Toyota Solvent
Yes. But it's a design to prevent MG2 from overspeeding. Also realize even though the ICE is always turning over approx 42 mph it may or may not be doing any work. Just because the ICE is rotating doesn't mandate it's using any fuel.
J
Curated Content Editor
Jul 19, 2014 12:30 PM
Jun 18, 2014 01:00 PM
Jason
Hybrid & Related News
22
Nov 3, 2005 06:27 PM
