Strut parts question
Old Feb 26, 2014 | 03:27 PM
UWAdventurer's Avatar
Default Strut parts question
I am considering replacement Monroe struts for my TCH. Part # 72307, 72308, 72309, 72310.
I see strut mate parts 906935, 906986, 903904. I assume I would need four of the 906935, two of the 906986, and two of the 903904 parts?
Any help on these parts is appreciated.
Old Feb 26, 2014 | 05:05 PM
litespeed's Avatar
Professor Emeritus
Default Re: Strut parts question
Pretty sure you want to use the KYB's to avoid the camber problem/issue with the Monroe's.
"ukrkoz" has a detailed post on this and the associated problems using the Monroe's somewhere.
EDIT:
Here is that thread: https://www.greenhybrid.com/discuss/...effects-29205/
Old Feb 26, 2014 | 06:56 PM
ukrkoz's Avatar
Yep, do NOT do Monroe. For few bucks more, really, you can have OEM KYB.
BIG difference is that KYB has 2 "lips" locking strut - and camber angle - on top of hub knuckle. With Monroe, you are solely relying on tension from strut bolts. I had to install camber bolts to be able to align camber.
Also, I do not like how Monroes ride. I am planning on replacing them with KYB-s around late spring. They didn't last long.
Old Feb 26, 2014 | 06:58 PM
ukrkoz's Avatar
Hmmmm... With that being said - I speak of the rear end KYB-s. You know, I am not really sure, if they do have those lips for the front ones on KYB. Or, for that matter, original struts. I simply did not pay attention.
Old Feb 26, 2014 | 06:59 PM
ukrkoz's Avatar
Actually they DO.
http://www.carid.com/2009-toyota-cam...FUaBfgodgLIATA
fanfaron
May 25, 2022 05:12 AM
UWAdventurer
Mar 4, 2014 07:14 PM
happy highlander
Toyota Highlander Hybrid
Mar 16, 2013 03:33 AM
ptung07
Dec 9, 2008 02:33 PM
TCHAL
Dec 1, 2008 05:43 PM
