Starter Battery Discharging
Old Mar 13, 2007 | 01:29 PM
skywagon's Avatar
Default Re: Starter Battery Discharging
Start pulling fuses one by one you will find where the juice is going lol
Old Mar 13, 2007 | 01:59 PM
Squint's Avatar
Malcontent
Originally Posted by SPL
Squint — The chances of this have got to be nil. The battery has already been replaced twice. The problem isn't the battery.
Yes, but it could prevent the 12V battery from running down and requiring a jumpstart until a permanent solution is found.
Old Mar 13, 2007 | 02:41 PM
obrienklm's Avatar
Stan,
You are right, the battery icon should remain "on" if the 12 volt battery is not being charged. The dealer has measured a maximum of a 22 milliamp steady drain after checking it multiple times over the 2 weeks they had it. I don't think they checked it continuously but just intermittent checks. They brought it to my home and to measure drain in my garage and still came up with just 22 m amps. You may be right re the battery control electronics. That seems the only logical reason that the first two batteries were “defective”. Maybe they were overcharged. They are supposed to be especially sensitive to over charging.
Old Mar 13, 2007 | 03:08 PM
Big-Foot's Avatar
Currency-to-hydrocarbons
Hi - Okay, I didn't want to comment until I tried it but - After sitting parked in my backyard covered in snow for almost 4 weeks, I went out and started the TCH and moved it around to put my truck in it's place.. A little concerned at first and this thread crossed my mind when the Proximity sensor did not detect the FOB and I had to push the button on the FOB to unlock the door (but that happens from time to time on this car anyway). Sat down, hit the brake and pressed the start button. Everything lit-up like Vegas and I was off and running as though it were parked there just yesterday.
Just driving it around the block it went into EV mode almost instantly (it's 61f here in Minneapolis today- YEAH!!)...
There you have it from another satisfied TCH owner who's glad he didn't have to jump-start his once dormant car..
Old Mar 13, 2007 | 05:31 PM
obrienklm's Avatar
Hi Randy,
Thanks for the comments and I'm glad to hear your positive experience. I'm from the Twin Cities too and that's what is really bugging me about this car. In Minnesota one has to have a car that starts. This is my 7th Toyota over the past 12 years and I've never had a hint of a problem with any of them until now. I got rid of 2 year old Acura TL to do the right thing...
(It was a great day today - snow is going, going gone!)
obrienklm
Old Mar 13, 2007 | 08:23 PM
Big-Foot's Avatar
Originally Posted by obrienklm
Hi Randy,
obrienklm
Yup - I figure we're in for one more good dumping of snow and then it should start to warm up.. 6 weeks of pleasant weather and then you know what happens?
FALL!
Just jesting...
BTW - My TCH sits outside all the time. When we had those 2 weeks of sub-zero in February it popped right off all the time and was not plugged in. I bought the block heater but have not had the chance / lift to install it yet..
If you ever need a good salesman in the area for Toyota - let me know..
Old Mar 14, 2007 | 02:58 AM
  #27
schmidtj's Avatar
Keeping Toyota Solvent
Maybe it's the crushed alluminum foil you use to line the inside of the battery cover?
Old Mar 14, 2007 | 04:08 PM
  #28
acco20's Avatar
Just read through all 27 posts on this problem, sorry about your experiance but it is interesting. I noticed you mentioned a couple of times that you always make sure everything is "off" and you always lock the car at all times when you leave it. It seemed to imply even at home in the garage, you lock your car. This is probably silly but........has the dealership checked the car with the doors locked? It may be possible that when you lock the car the electronic parts that perform that chore are sticking in the on possition, and after several days could cause a dead battery. Just a thought...........but maybe???????
Old Apr 3, 2007 | 01:40 PM
  #29
obrienklm's Avatar
Update on the dead battery saga… I was away last week and my TCH starting battery was stone cold dead again this morning. I think that is the 6th time it has been dead when left more than a couple days. As always it started immediately with a jump and my dealer again promised to figure out what’s causing the drain. And… they think they have it!!!
It seems that Toyota has notice several similar problems with the THC, all in the northern states, and they have tracked it down to a problem with the computer that controls the remote start. Apparently there is a malfunction between the smart key and the remote start program that is draining the battery over time. They plan to install a new computer tomorrow and hopefully the problem will be solved.
I’ll let you know and again, thank you for the many constructive ideas and all the great information provided on this issue.
Regards, Keith
Old Apr 3, 2007 | 02:40 PM
  #30
SPL's Avatar
SPL
obrienklm — Aha! I didn't know you had remote start! This is something we hadn't considered, I guess, but this is some more electronics that must remain powered all the time to receive remote-start commands. Based on your experience, it would have to be programmed to power itself down after only a single day of non use of the TCH. [The Smart Key progressively powers itself down over a 2-week period of non-use to save the 12-V battery.] But then it wouldn't be very useful! So, how's it going to work in the future?
Stan
