squealing wheels?
Old Sep 17, 2006 | 03:09 PM
IMAhybrid's Avatar
Vegetarian
Default Re: squealing wheels?
Originally Posted by flopshot
My tires squeal quite often when I'm making a turn from a dead stop. Note that I do not get tire squeal when I go straight from a dead stop.
That's because in order to make a turn the inside tire needs to turn slower than the outside tire, because it doesn't need to travel as far. See what I'm saying? The squeeling would occur when the inside tire is spinning faster than it needs to... which is probably about the same as the the outside tire, which wouldn't cause problems when going straight.
Old Sep 18, 2006 | 10:57 AM
JMV's Avatar
JMV
Hey guys..when I turn sometimes I get a howling sound from the tires(best description I can think of is:the kind of sound one gets after the brake pads are replaced but not the rotor)..is that normal or should I b concerned?????
houstoib
Aug 3, 2011 12:36 PM
MMH06
Feb 19, 2010 07:08 AM
MMH06
Oct 27, 2009 07:11 AM
SAM Hybrid
Jan 8, 2006 07:52 PM
