Speedometer 4-5 mph under actual speed
Old Nov 13, 2006 | 11:27 AM
ag4ever's Avatar
Dazed and Confused
Default Re: Speedometer 4-5 mph under actual speed
A dynometer is not a scan tool. It is a device that the car's drive wheels are placed on a large drum or sometimes two small drums. the drums spin with the wheels, and the speed of the turning drums shows the real ground speed of the tires. They are very accurate is calibrated correctly. You might look in the yellow pages for a radio shop that does speedometer work. They usually have the same type of dynometers to check vehicle speed. Then if the dealer's and the independent shops numbers match, case closed, if not you can get a certified copy from the speedo shop to use against the dealer.
Old Nov 13, 2006 | 06:53 PM
ken1784's Avatar
Default Re: Speedometer 4-5 mph over actual speed
Originally Posted by wallpad
That ECE spec looked very European though. Is it what Toyota uses for American cars also? If yes, then I think I am done with this issue, dissatisfying though it may be.
Yes, the main members are in Europe, but Japan, Australia and New Zealand are also the members.
A regulation is discussed at World Forum for Harmonization of Vehicles Regulations(WP.29) and the US and Canada also attending the forum.
http://www.unece.org/trans/main/welcwp29.htm
I don't know how the US government is treating this, but there is no good reason to against the regulations.
I believe it is nice to set such standard regulations worldwide.
Ken@Japan
Old Nov 17, 2006 | 03:52 PM
scottzorch's Avatar
Around my neighborhood we have speed limit signs with radar guns built into them. They tell you how fast you are going along with the actual speed limit.
The speed indicated on these devices is consistently 4-5 mph lower than what my speedometer shows.
I know that most car speedometers show mph a couple miles below actual, but 4-5 mph seems too much.
Is anyone else's TCH speedometer this far off?
Paul
I know that the thread is basically over, but I thought I'd add two data points. I have about a 3mph difference between GPS and speedometer on my TCH. On my previous car (2003 Corolla CE) the divergence was about 2mph.
Curated Content Editor
Jan 7, 2013 05:10 PM
acco20
Jun 28, 2009 03:35 AM
pBen
Dec 4, 2007 07:10 AM
Orient Express
Dec 13, 2006 10:41 PM
bwilson4web
Apr 1, 2006 12:23 PM
