Signatures
Old Jan 18, 2008 | 06:33 AM
nicst47's Avatar
Default Re: Signatures
Originally Posted by KTLane
the link that's wandering out in front of the image needs to be inside the the "a href" tag makes the image into a link, since the image ("img src") tag is contained between the "a href" and the "/a"
arrrggg!!!
Old Jan 18, 2008 | 07:04 AM
CJO2007CamryHyb's Avatar
Yes.........having taken WML and XML, HTML is very similar. I saw a post a while back on exactly how to make the signature show up and it was not hard to get it to work after that.
Old Jan 18, 2008 | 07:05 AM
KTLane's Avatar
blahhhhhh!
paste me what you have in your signature box... enclose it in quote tags (the little quotation symbol above in between the # sign and the mountain-picture
Old Jan 18, 2008 | 07:06 AM
It looks like you have the right script code now Kate...........your signature looks good now!!
Old Jan 18, 2008 | 07:12 AM
nicst47's Avatar
https://www.greenhybrid.com/compare/mileage/car/6356.html" style="border:0" title="Hybrid Cars Mileage">
Old Jan 18, 2008 | 07:19 AM
KTLane's Avatar
blahhhhhh!
I think you should try erasing everything and then repasting it, making sure it matches exactly what you're pasting from.
I found another way to do it, but it's not letting me paste it correctly, it turns into an image, even if I quote around it.
Old Jan 18, 2008 | 07:34 AM
  #27
nicst47's Avatar
Ok, I erased everything and started over.
Old Jan 18, 2008 | 07:35 AM
  #28
That's what mine does too. I think that's the way the HTML code is written in this website.
Old Jan 18, 2008 | 07:45 AM
  #29
wdmark's Avatar
Originally Posted by nicst47
arrrggg!!!
Nick I created your signature within mine (don't worry I'll remove it when you're good to go) as follows:
Try this sequence within the User CP Signature Edit screen:
Clear out everything in your existing signature
Click on the Insert Image icon (4th from right) and then insert (cut & paste), the Image Properties http address below (without the <> I had to use to get it to display here)
Image Properties <https://www.greenhybrid.com/compare/mileage/car/6356/signature.png>
Once the image of your signature appears, highlight/mark/select the image as if you were going to copy it.
Then click on the "Insert Link" Icon (7th from right) and insert the http link location below
Link Location https://www.greenhybrid.com/compare/.../car/6356.html
Add any other text you want in your signature and save. You should be good to go with a signature that will link to the mileage database.
Anyone else can duplicate this process by substituting their car # for your 6356.
Hope this helps...it took me awhile yesterday to figure this alternative to coding and get mine hot linked to the database.
P.S. You can right click on any image (e.g. any signature pic) and select properties to get the address(es).
Old Jan 18, 2008 | 07:57 AM
  #30
nicst47's Avatar
Thanks, I hope this worked.
