Should I get the CAMRY HYBRID rustproofed by KROWN?
Old Apr 15, 2015 | 12:46 PM
2009TCH's Avatar
Default Should I get the CAMRY HYBRID rustproofed by KROWN?
I really need good advise on this. Has anyone gotten their hybrid rustproofed by KROWN? Can the petroleum based chemical damage the insulation of the high voltage cables.
Old Apr 17, 2015 | 10:11 AM
haroldo's Avatar
Default Re: Should I get the CAMRY HYBRID rustproofed by KROWN?
I don't know, but my 2008 doesn't have any rust.
Do cars still rust?
Old Apr 17, 2015 | 10:37 AM
2009TCH's Avatar
Yes they do. I have a bit of surface rust.
Old Apr 18, 2015 | 09:07 PM
Sooty's Avatar
I've told by a number of people in the industry that just like asphalt driveway sealer, rust proofing the underside of cars is a waste of money.
Old Apr 18, 2015 | 09:36 PM
2009TCH's Avatar
Its not about sealing. KROWN is a oil based rust proofing that has to be applied every year and it remains on the entire body of your car. It is sprayed in a mist solution inside all the door, bonnet, trunk, body panels and the underside. The only downside being that it might affect rubber components. In Canada we get a lot of salt, snow, moisture here. Temperature ranges from -30C to +30C.
Old Apr 19, 2015 | 09:05 AM
Sooty's Avatar
Originally Posted by 2009TCH
Its not about sealing. KROWN is a oil based rust proofing that has to be applied every year and it remains on the entire body of your car. It is sprayed in a mist solution inside all the door, bonnet (hood), trunk, body panels and the underside. The only downside being that it might affect rubber components. In Canada we get a lot of salt, snow, moisture here. Temperature ranges from -30C to +30C.
If it's any help to you I also live in Canada. I have never had a problem with rust. We currently drive a 2007 Camry Hybrid and a 1999 Corolla neither one has any rust and neither one has been after market rust proofed.
They use galvanized steel these days so all auto-body parts are rust proofed before they are painted.
Why Buy a Toyota? http://randythecarguy.com/quality.htm
Globe and Mail article from 2011
Old Apr 20, 2015 | 08:06 PM
GeorgiaHybrid's Avatar
Any modern car is e-coated by dipping after it is formed. Unless you have had body damage from a wreck that was not repaired correctly, I doubt that you will ever have any rust in the NORMAL lifetime of the car.
jimmy1
Nov 29, 2018 06:44 PM
mach22
Apr 10, 2007 09:36 AM
collegejester
Toyota Highlander Hybrid
Mar 7, 2007 08:34 AM
NEWNEW
Mar 19, 2006 07:06 AM
