Seat belt warning alarm
Old Dec 21, 2010 | 11:25 AM
  #61
jasonshybrid's Avatar
Default Re: Seat belt warning alarm
smilin jack, eloquently said!!!
i have a long driveway, which leads to a rural road, which then leads to a more populated road. i usually have belted up by the time i hit the rural road, as i feel naked without a seat belt. but even as i grew up always belting up, this seatbelt indicator drives me insane!! im gonna turn it off at my earliest convenience.
Old Dec 21, 2010 | 11:29 AM
  #62
hamm3r's Avatar
I'm with you 100%.
All I know is that my nearby dealer lost a ton of service because they at first refused to disable the chime at all during one of my service intervals. Later they tried to charge me $100. That was the last time I have used them. The dealership that has done it for free is further away and has taken over my service intervals and even sold me a new set of tires. Dealerships that care about good customer service get good customers.
Old Dec 21, 2010 | 02:11 PM
  #63
SanAntonio Joe's Avatar
As for belts, I KNOW they work. I have survived several crashes that I should not have due to belts and airbags. (And no, I don't want to hear your "but what if...." questions or stories--belts WORK.)
Next, the Toyota chime is annoying. I own a Chevy Silverado pickup, Cadillac Deville, Chrysler Sebring convertible, and have owned Lincolns and Buicks. This chime in the Toyota is ANNOYING! It comes on too LATE to be a reminder, and is too loud and high pitched.
Having said all of that, here are some instructions I found on another Web site; I plan to try them out tonight on my car:
TURNING OFF THE SEAT BELT BEEPER
If you touch the brake pedal, it will screw you up, so feet off the brake from the second you get in the car. I also had all doors closed, not sure if that matters.
- put in your key and turn the car on, do not start the engine
- Set the LCD on the combination meter to the ODO trip.
- turn car back off for a minute
- turn it back on
- Press and hold the TRIP meter reset **** for ten seconds or more within six seconds of turning the ignition switch to the ON position.
- Fasten the driver's seat belt while holding the **** (this is the tricky part)
- as soon as you fasten the belt, the LCD should change
You may have to hit the reset meter **** to cycle through b-ON to b-OFF (b-off, obviously turns the belt warning off)
- once you set it to b-off, just sit there and wait and the lcd will return to normal, turn the car off you are done.
If you miss any of the little things, it will not work.
Old Dec 21, 2010 | 03:12 PM
  #64
wow, let us know if that works cause if thats true that is EPIC news.
Old Dec 21, 2010 | 03:56 PM
  #65
hamm3r's Avatar
- turn it back on
We have tried all of these tricks with no luck. By the way, when you figure out step 1, let us know ("put in your key"). I think these instructions are for older model Camrys.
Old Dec 24, 2010 | 08:00 AM
  #66
ukrkoz's Avatar
chime goes away in about 30 seconds. red light keeps blinking until belt is buckled.
also, if you have fairly heavy object on passenger seat, ECM believes you have unbuckled passenger and will chime for that side either.
be grateful they did not couple engine immobilizer along with seatbelt sensor.
Old Dec 24, 2010 | 11:35 PM
  #67
McGyver's Avatar
I posted a permanent fix about a year ago.
Old Jan 5, 2011 | 07:32 PM
  #68
link to said permanent fix? you should put it in your sig too!
zebrajeb
Jul 30, 2008 09:33 AM
JTode
Feb 28, 2007 04:00 AM
vioarc
Sep 11, 2006 07:27 PM
bakerx3
Sep 8, 2006 11:56 AM
RoyalF
Oct 18, 2005 01:31 PM
