Seat Belt Ding
Old Nov 21, 2006 | 04:49 PM
M_J's Avatar
M_J
Default Seat Belt Ding
Does anyone know if there is a simple fix to make the dinging go away when you dont plug your seat belt in. Is there a fuse or bypass to make it go away???
Old Nov 21, 2006 | 05:50 PM
skywagon's Avatar
Default Re: Seat Belt Ding
Ya, go to the dealer and tell them u have a family member that is around 350 lbs. they will order u a extender for free. plug the extender in and U R good 2 go.
Old Nov 21, 2006 | 06:37 PM
Big-Foot's Avatar
Currency-to-hydrocarbons
I'm a major advocate of seatbelts and their use as probably many others on this site are.
I'll spare you the lecture since you're obviously capable of making your own decisions right or wrong.
I have a friend who found that he could just pull the seatbelt connector towards the rear of the seat, stretch the harness behind the seat and plug it into the connector. He leaves it that way all the time.
I hope I don't have to attend his funeral..
Old Nov 21, 2006 | 07:03 PM
skywagon's Avatar
Randy, i agree 100%, I would not go across the street without one but a lot of folks do not use them. Same with motorcycle helmets but thats a different story lol.
Old Nov 21, 2006 | 07:06 PM
JHSmith's Avatar
I, too, am a proponent for seatbelt usage. (Have been since my father had '62 VW bus. Needed belts just to stay in seat. My mother rolled it, and only thing saving us was the belts.) That said --
You CAN bypass the "ding" by permanently inserting the catch from the Toyota Seat belt Extender. -- Problem: According to the TSB on Seat Belt Extenders (page 7), keeping the extender permanently attached will disarm the airbag. I assume that keeping the normal seatbelt connected would probably result in the same thing happening with the air bags. (Yes, I know about the saying concerning the word "assume".)
File Type: pdf
Old Nov 21, 2006 | 09:59 PM
jkyu99's Avatar
I have to think that if someone wants to disable the seat belts, they probably don't need the airbags either. At first I was going to take the morale high ground about seatbelts, but then again, I ride a motorcycle without seatbelts or airbags. Oh well.
"keeping the extender permanently attached will disarm the airbag"
Old Nov 21, 2006 | 10:33 PM
SFHybrid's Avatar
I too am for seatbelts. But when I did not put mine on right away the dinging stopped after one minute.
Old Nov 21, 2006 | 11:09 PM
Gary Yost's Avatar
There's a system setting (SEATBELT WARNING) for this that's described here:
http://toyotaiguide.com/iGuide_Camry.htm
Your dealer can make this change for you. (He did for me, along with changing 7 other system defaults.)
Old Nov 22, 2006 | 04:39 AM
klynch's Avatar
Gary,
Did the dealer charge you for changing the other system defaults? I don't want to disarm the seatbelt warning, but I'm tired of the air conditioner turning on whenever it pleases...42 degrees outside, cabin temperature set at 72, and the "auto" light comes on along with the air conditioner! (No, I didn't have the switch previously set to "auto.")
Old Nov 22, 2006 | 06:36 AM
hamm3r's Avatar
I would like to disable the chime as well, but I want to qualify:
I am 100% for seat belt use and have used them way before usage ever became law.
BUT, as we approach our house my wife likes to take hers off a few feet (sometimes more) before we pull into the driveway. The dinging is crazy annoying and unnecessary at this point.
Clublexus.com has a post on how to disable the buzzer on the lexus. I tried it out and it does not work. Guess I have to have the dealer do it.
