Satellite Radio
Satellite Radio
Has anyone had the dealer install the satellite kit? Is it that much better than the FM modulator?
I just got my TCH and had Sirius in my old car. I took the antenna and receiver out of the old car and installed it in the TCH. (Being very, very careful about the paint on the TCH). It works fine, however, I noticed that due to the powerful antenna on the TCH I had trouble finding a clear radio station. I also noticed that I need to turn up the volume when I'm on satellite, compared to normal radio stations.
My dealer will charge me $400 to install the adapter for Sirius on my TCH and I was wondering if anyone thought it was worth it.
PS - I LOVE the gas mileage
Re: Satellite Radio
After hearing about all the issues about static related and as well as the delay of the Camry Fit Kit for Sirius. I gave up and decided to just use a Starmate Replay in the car. I found the 'best sound' is not thru the FM Modulator but thru the Aux in-put jack located under the radio.
I will warn you the reason I say this is the 'best sound' is there is a grounding issue so I get a slight buzz sound when I have my Starmate plugged into the power outlet. Cruchfield.com sells a grounding kit that is said to help eliminate the buzz but I have yet to try it out.
I hope this helps.
Hector
I hope this helps.
Hector
Re: Satellite Radio
I got the Toyota Sirius kit that integrates in the radio. It is not bad, but there were 2 problems, one was a major static issue that there is now a fix for, a jumper. The other is the crappy windshield antennea which has no fix other than to by an OEM antenne and mount it on the roof, which I did. The Toyota antenna was casuing drop outs all the time, other than over passes I have not had one since installing the OEM roof ant.
Re: Satellite Radio
Why don't you just plug your receiver directly into the Aux jack? That's what I did - bypassing the FM issues. I'm loving it!
"I will warn you the reason I say this is the 'best sound' is there is a grounding issue so I get a slight buzz sound when I have my Starmate plugged into the power outlet." I'm not noticing any buzzes, and I'm using the Starmate, too. Hmmmmm. Maybe it's the adaptor you're using. We're using one made for the Starmate.
Re: Satellite Radio
Thanks much...
Re: Satellite Radio
Read his post again. He Does use the aux jack.
The buzzing sound comes from using the power outlet, I know because mine does it. (I also have Sirius running through the aux jack.)
I have factory installed XM and the antenna is in the back deck, near the rear speaker. It is fine. My mom also has the same location and hers is fine.
Re: Satellite Radio
I guess there's some kind of punch-out on side of the center dashboard post on the passenger side - he punched that out to get to the antenna cable from inside the bottom door (the one with the aux jack) and threaded it though there, somehow. He then replaced the punch-out.
My Sirius receiver plugs in to everything (antenna, aux, power) behind that door at the bottom of the center dashboard. My reception is great.
I know I'm not the most helpful person in the world, but if I can get my husband to elaborate a little more, I'm sure his description will be much better.
Re: Satellite Radio
Kluken... I have a Toyota XM kit with horrendous dropout problems from the (crappy) windshield antenna and I'd like to add a roof antenna, but haven't done anything like that before and don't know how to do it without jeopardizing the back window integrity, seals, etc. Is there a link to someplace on the web where your installation technique is described or can you please post a detailed description of how you did it?
Thanks much...
Thanks much...
