Replacing back up lights
Old May 21, 2011 | 06:54 AM
haroldo's Avatar
Default Replacing back up lights
My back up light is out. I looked at the manual, p. 339 and found this
Lights other than the above If any of the lights listed below has burnt out, have it replaced by your Toyota dealer.
l Front turn signal/parking lights
l High mounted stoplight
l Side marker lights
l Tail lights
l Back-up lights
Not crazy about setting up an appointment to handle this.
Is there an easy way for a moderate level DIY-er to handle this?
Thanks!
Old May 21, 2011 | 03:07 PM
SteveHansen's Avatar
Pragmatist
Default Re: Replacing back up lights
You just have to remove the felt trunk-lid liner to get at the back of the socket.
The felt is held in place by plastic clips. To disengage a clip, pull on the 'middle' round part, NOT on the outer ring. If you break one, replacement clips are available: http://www.trademotion.com/partlocat...layCatalogid=0
The bulbs are 18 watt. http://www.trademotion.com/partlocat...layCatalogid=0
Old May 21, 2011 | 03:14 PM
haroldo's Avatar
Thanks! Those clips scare me...I can see myself destroying them....all of them!
Old May 21, 2011 | 03:18 PM
Pragmatist
I just pulled a couple of mine to look at them, before I wrote that. I used fingernails, not tools.
Old May 21, 2011 | 04:01 PM
jbollt's Avatar
No big deal to open and reuse these clips. I installed a factory spoiler on my 09 TCH, and had to remove the trunk lid liner. As has been mentioned, gently pull out on the center of the clip, then the whole clip will easily pull out. Once you see one in your hand you will understand how they work.
Old May 23, 2011 | 05:57 PM
haroldo's Avatar
Yup, easy, thanks!
Love the three minute DIY jobs that don't get your hands dirty!
Old May 23, 2011 | 06:20 PM
Pragmatist
Just for grins -- did you get a quote from the dealer for replacing that light bulb?
I'm guessing 1/2 hour labor at $175/hour, plus $25 for the part, and $40 for "shop supplies".
Old May 23, 2011 | 06:37 PM
haroldo's Avatar
Nah, my dealer does minor stuff, wipers, etc., gratis. (now Firestone would be another story)
Best part of the backup bulb is it was at eye level, no need to bend over or reach into engine to access it, pop the trunk and it was right in front of me
TDactor
Sep 30, 2014 08:31 PM
lebloom
Mar 11, 2011 11:07 AM
psyshack
Saturn Vue Green Line
20
Aug 1, 2008 06:38 PM
tya2agt
Jul 4, 2008 05:18 AM
hahguy
Jun 14, 2006 06:30 PM
