Recommended snow chains for TCH
Old Nov 9, 2008 | 06:19 PM
mikecism's Avatar
Default Recommended snow chains for TCH
Can someone recommend some easy to use snow / tire chains for the TCH. (Chain, cable, etc.)
Thanks.
Old Nov 10, 2008 | 09:41 AM
wwest's Avatar
Default Re: Recommended snow chains for TCH
If you have a need for traction devices, tire chains, etc, on a regular basis then you should NOT be driving a FWD vehicle. "Tire chains" can only be effective on the drive wheels and putting tire chains on only the front of a FWD vehicle can turn HAZARDOUS in an instant.
If you insist on doing so anyway then I would advise "tire chains" front and rear simultaneously, as your owners manual directs, or otherwise NEVER driving above DEAD SLOW with tire chains on the front only.
Old Nov 10, 2008 | 10:54 AM
livvie's Avatar
i didn't see anything from mike suggesting he wouldn't put on all 4 wheels but that is good to know. anyway, where do you live? if you are gettting a lot of snow, why not invest in a set of dedicated snow tires?
Old Nov 10, 2008 | 12:41 PM
wwest's Avatar
Snow tires do no good on an icy/slippery surface such as a patch of black ice. Snow, winter specialty tires are only of any good if the surface is "soft" or "loose" enough for the tread to have "bite". You are much better off staying with nice quiet and more comfirtably riding summer only tires and then installing chains in the rare times, generlally, of need.
Old Nov 12, 2008 | 09:04 PM
mikecism's Avatar
I am not an idiot. I have driven in snow plenty of times with 4WD and 2WD. And yes, only with chains on the FWD. In CA/NV (the Sierra Nevada), that's how it's done. It not HAZARD in an instant to put only chains on the FWD axle - it's been done that way for years. Yes, and you drive slow.
Obviously 4WD is best. But in some mountain areas, you are required to carry and use chains when directed (which are not needed below the snow level, ex Sierra Nevada).
I'm just asking if there is a chain or cable someone with a TCH has used and recommends.
Old Nov 13, 2008 | 07:09 AM
livvie's Avatar
I don't know, I've lived in NH for many years and have gone through every type of road condition imaginable and have never needed to use chains. I've haven't had a situation where my snow tires couldn't handle it.
Old Nov 13, 2008 | 07:07 PM
zebrajeb's Avatar
Thanks.
To answer part of your question, I recommend these "Quick Fit Diamond chains" from Les Schwab
http://lesschwab6.reachlocal.net/tir...ter/chains.asp
They are not cheap but easy to put on and take off.
For snow tires, I bought Blizzaks last year from Tire Rack. Picked them up at Tire Rack and didn't have to pay shipping!
Just what I'm using that has worked for me. Like you mentioned, the Sierra can require chains sometimes!
John
Old Nov 17, 2008 | 10:19 AM
Sky Blue's Avatar
This IS a great thing to question and find out....
I live in a non snow area and a couple times a year drive up to Tahoe (Sierra Nevada) and was wondering what chains to use. You carry them in case you need them due to snow flurries covering the roads.
Once the roads get a chance to be cleared, you can take them off and put them in the trunk in case needed again.
LOL to the people who live elsewhere!
Old Nov 17, 2008 | 11:13 AM
GeorgiaHybrid's Avatar
Guys,
Not that I need chains in Georgia (other than to help pull out a stump with my truck) but the manual on pages 166 to 169 gives the specs for chains. They are also used ONLY on the front axle. I have used them in the past and prefer using a cable style instead of chains (they just seemed easier to use) but the manual does not mention them.
Old Nov 18, 2008 | 12:14 AM
GreenRedTCH's Avatar
I think what Mikecism is referring to is when this sign appears:
http://www.wsdot.wa.gov/NR/rdonlyres...s_required.jpg
Needed or not, you must have the chains on or the highway patrol will issue a ticket. Count me in as one who would like a good recommendation.
