Rear Breaks Rubbing
Old Mar 14, 2008 | 06:25 PM
LouBeck's Avatar
Default Rear Breaks Rubbing
About 6 months ago, my rear breaks started making a rubbing noise when cold,light pressure, in reverse, for the first couple of stops. I have taken it to the dealer 2 times. I have 16k, almost two years old now. They said it did not fall in the vin range for the TSB. They sais they saw some glazing of the discs. They recut the rear rotors and sanded the pads. It is somewhat better, the neighbors stopped looking at me, but it is still there. On my next visit, I may insist they perform a full break job, replacing the pads and possible discs, I do not want them cut again. Any ideas?
Old Mar 15, 2008 | 12:49 AM
haroldo's Avatar
Default Re: Rear Breaks Rubbing
I'd bring it to a private mechanic you trust and ask his opinion.
Old Mar 15, 2008 | 06:46 AM
mikieboyblue's Avatar
Also make sure they were looking at the -07 TSB that replaced the -06 brake one. (I cannot remember the rest of the number.)
UPDATE:
"The new TSB BR007-07 replaces TSB BR010-06."
I had the -07 done which is for rear brake squeak and premature pad wear.
Here is the thread:
https://www.greenhybrid.com/discuss/...per-tsb-16903/
Last edited by mikieboyblue; Mar 15, 2008 at 06:50 AM. Reason: Added reference content.
Old Mar 18, 2008 | 08:03 AM
LouBeck's Avatar
Dealer finally agreeed to replace the rear pads as soon as I can schedule it under the 2007 TSB. My questions is now that they have already cut the discs in an attempt to fix it, should I press them to replace them?
Old Mar 18, 2008 | 10:49 AM
Well if there was glazing on the discs then I would suspect that would cause a problem with the new pad (additional wear?). If the discs are clean, I would keep them. I actually have a hard time finding places that will cut the discs -- they all seem to want me to replace them.
Old Apr 1, 2008 | 11:20 AM
HoustonRealtor's Avatar
I took mine in last night and the rear brake pads have been replaced and shims added, per the TSB. I'll pick it up later this afternoon and hope that it's fixed!
Old Apr 1, 2008 | 11:25 AM
LouBeck's Avatar
Mine were finally done last week after my third visit, they agreed to replace the discs, but then did not have them in stock, and would not put on aftermarket claiming they are inferior. My concern it that they claimed to have resurfaced the drums one week before, I do not feel they ever did, so by there recoreds they resurfaced them 2 times, by my inspection at most they just sanded them the first time. This is in there recored and if they warp they are on the hook.
Mel2001
Feb 4, 2014 04:43 PM
CYKBC
Oct 15, 2012 08:44 PM
Jason
Hybrid & Related News
19
Mar 13, 2006 06:54 PM
Jason
Dec 24, 2005 01:39 PM
