Quick Question
Old May 26, 2006 | 07:29 PM
Railroad's Avatar
Default Quick Question
Hi,
I'm just wondering, but say the battery dies in the Camry hybrid, can the car still run on its 4 cylinder engine like the Accord Hybrid can? Or is it like the Prius?
Thanks.
Old May 27, 2006 | 12:34 PM
ericbecky's Avatar
Contributor ($)
Default Re: Quick Question
More like the Prius.
Old Jun 3, 2006 | 09:40 PM
Railroad's Avatar
I have another question, just going use the same thread.
Test drove the Camry hybrid today, the base model and I gotta say, wow it was quiet. The salesman thought it wasn't working since there was no noise at all.
Question is, where do you read your MPH stats? Or is it just in the top model only? There was a fuel consumption meter besides the odometer. I guessed that when you're in electric, the needle would be at 0 and what not.
Old Jun 3, 2006 | 11:36 PM
stevenvillatoro's Avatar
Arrow Re: Quick Question
Apart from the optional NAV screen, all models have a display screen in the center of the speedo gauge. This display screen cycles through a total of nine displays, which include things like outside temperature, average fuel economy, cruising range, battery management, etc.
The instantaneous mileage meter that you mentioned will register from 0 (zero) to 60 MPG in gas engine (ICE) mode. When operating on batteries only (EV), the meter will skyrocket past 60 to indicate that the gas engine has shut off, rather than falling to zero.
Glad you liked the quiet ride. Shhhhhhh.
Old Jun 4, 2006 | 12:23 AM
CGameProgrammer's Avatar
The "ECO DRIVE" indicator shows you trip mileage since the car was started. It's displayed somewhat annoyingly as a bar that fills up. If you get 26 mpg, one bar on the left will be filled. Getting 41+ mpg, all will be filled. It can really only show trip mileage between 26 and 41 mpg.
When you start driving, your mileage will be less than 25 mpg for a little bit, but eventually it'll increase and you'll start seeing the bars fill on the gauge.
Old Jun 4, 2006 | 04:10 PM
Railroad's Avatar
Oh I see. Thought it was the other way around.
Thanks for the replies. Too bad I'll have to wait another month for it though.
Old Jun 4, 2006 | 05:41 PM
fullofbeans's Avatar
Electricity Guzzler
My understanding is if the traction battery somehow is totally drained you can't drive only with ICE. I believe if you run out of gas you can drive in LIMP mode for approx. 2 - 4 km though.
jonjonbear
Aug 3, 2007 07:11 AM
tnsig
Feb 23, 2007 06:16 AM
JOE540CI
Toyota Highlander Hybrid
Dec 13, 2006 07:31 AM
simpleman
Introductions
Nov 15, 2006 05:58 AM
Run_n_Late
Apr 10, 2006 05:24 PM
