Problem filling up at gas station
Old Dec 17, 2016 | 04:24 PM
acarl10's Avatar
Default Re: Problem filling up at gas station
Bugs, I was wondering if you got this worked out? I am having the same problem. How do I check the spring?
Old Dec 20, 2016 | 05:08 AM
haroldo's Avatar
Originally Posted by acarl10
...How do I check the spring? ...
Press the button inside the car
If the flap opens, the spring works
If the flap doesn't, the spring is broken or missing
Replace it.
It's an $8 (??) part available at Toyota...an average DIY-er can replace it in approximately 90 seconds (not including time spent opening the box)...YMMV
Old Dec 21, 2016 | 12:53 AM
WMConey's Avatar
Replace it.
Mine is at the point of intermittent failure. Can you do the car-fixit-impaired group of us the favor of :
a) where is the spring, specifically? [yes, I've looked - I used to be an engineer on >US$10M automated semiconductor manufacturing equipment, its not obvious] Maybe a picture?
b) What is the part number if I buy it at my local dealer?
Thanks and regards.
Old Dec 21, 2016 | 02:47 AM
haroldo's Avatar
The dealer will know the part number
watch this
Most of the dealers or parts guys will pop it in for no charge (YMMV). Just ask the guy when you pick up the spring, I'm sure he'll help
Old Jul 4, 2017 | 04:58 PM
ron77reed's Avatar
Originally Posted by RadioTek
Anyone else notice this? The nozzle shuts off after getting less than a tenth of a gallon. I've noticed it on the "Elephant Trunk" type vapor recovery nozzles, because that's the only ones we've used in the last few months. I only have to fill up once a month, we don't drive a lot.
But it turns a trip for gas into real pain in the butt.
Anyone else seen this?
Scott
I had this same problem with my 2008 Camry Hybrid. Other symptoms prompted the replacement of the 12 volt accessory battery. The next fill up, problem solved!
rigger
13
Feb 17, 2008 09:27 PM
Orcrone
Jul 17, 2006 06:57 PM
Delta Flyer
Off Topic
Apr 13, 2006 06:51 AM
06 HCH in Georgetown TX
Mar 7, 2006 05:23 AM
