outdoor temp
Old Jan 25, 2008 | 03:57 AM
KTLane's Avatar
blahhhhhh!
Default outdoor temp
Am I crazy or does the temperature only display in even numbers when the temp gets below zero? I left home and it was 1°F, but on my way to work it got down to -8, then "warmed" to -6, -4 but never -5 or -7. Has anyone else noticed this, or am I the only one who cares about the outside temp so much?
Old Jan 25, 2008 | 04:55 AM
haroldo's Avatar
Default Re: outdoor temp
I guess once you get below zero, it really doesn't matter whether it's -5 or -6...it's COLD!
Old Jan 25, 2008 | 05:05 AM
KTLane's Avatar
blahhhhhh!
you're telling me! I wish whenever it got below +20°F that it would just say COLD instead of the real temperature.
This weather makes your eyes water and the tears freeze to your face
Old Jan 25, 2008 | 06:04 AM
obrienklm's Avatar
Pretty sure I saw -9 all the way to work yesterday but can't remember for sure, memory could malfunction when it's that cold.
Old Jan 25, 2008 | 07:02 AM
jbollt's Avatar
While I can't speak about temps below zero, (BRRRR) I can provide some explanation...There was a thread on this some time ago. It seems that the temps are collected in degrees C and converted to degrees F, causing that apparent 2 degree jump behaviour.
check this thread for more details.
https://www.greenhybrid.com/discuss/...celsius-12462/
Old Jan 25, 2008 | 09:18 AM
rmorrow's Avatar
Good thing then that the Canadian version uses "real" degrees...
Old Jan 25, 2008 | 11:13 AM
KTLane's Avatar
blahhhhhh!
I don't expect ANYTHING to work when it's that cold out
Don't get me started on how I wish the US would convert to metric
Makes sense! Although in the thread you pasted, I only experience this behavior when it's below zero, not below 32°F.... Odd?
Old Jan 25, 2008 | 11:28 AM
mikieboyblue's Avatar
Maybe you just don't notice? I certainly don't pay that much attention.
Old Jan 25, 2008 | 11:30 AM
KTLane's Avatar
blahhhhhh!
I only remember because it was 1 when I got in the car this morning... which was like 5 or 6 degrees warmer than what my outdoor thermometer said?
Old Jan 25, 2008 | 11:33 AM
Yeah, I do not trust that temp at all. To me, it is mostly useless. I sometimes use it to determine how close it might be to freezing so I know if I should slow down a little... :-D
